Divergence Explained: Velocity & Density in Fluid Flow
  • Thread starter ehrenfest
  • Tags
    Divergence
F the same as the divergenceIn summary, divergence is a concept in fluid flow that refers to the rate at which density flows out of a given region. It is interpreted as the rate of change of velocity, or acceleration, and is related to the flux of the velocity through an infinitesimal volume. The rate of change of F, or the velocity, is equivalent to the divergence.
ehrenfest
2,020
My book says that divergence can be understood in the context of fluid flow as the rate at which density flows out of a given region. It says that if F(x,y,z) is the velocity of a fluid, then that is the interpretation of the divergence. I fail to understand where the density comes in when we are only dealing with velocities at first and we only take a spatial derivative. It seems like the interpretation should be the rate of change of velocity i.e. acceleration.
"Acceleration" implies a velocity changing with time. If you have a fluid flowing toward a central drain, for example, the velocity may vary with position but not time. A single molecule of the fluid could move toward the drain with constant velocity while different particles, around the drain, move with the same speed but different velocities.
Rate of fluid flow is related to volume, and not mass so the density doesn't enter...
Do you see how over a closed volume... the rate at which fluid is leaving the the volume is F.A (dot product of velocity with the area) over the volume... ie the flux of F through the area enclosing the volume...
OK and you just make that volume infinitesimal? How does making the volume infinitesimal get you the equation for the divergence? Is
1. What is divergence in fluid flow?
Divergence in fluid flow refers to the rate at which fluid particles are moving away from a specific point in the flow. It is a measure of the spreading or convergence of fluid flow and is caused by differences in velocity and density within the fluid.
2. What causes divergence in fluid flow?
Divergence in fluid flow is caused by differences in velocity and density within the fluid. This can be influenced by various factors such as changes in pressure, temperature, and the shape of the flow path.
3. How is divergence calculated?
Divergence is calculated by taking the partial derivatives of the velocity components in the x, y, and z directions and adding them together. This can be written as div(v) or ∇·v, where ∇ represents the gradient operator and v represents the velocity vector.
4. What is the relationship between divergence and incompressible flow?
In an incompressible flow, the density of the fluid remains constant, meaning that there is no change in density over time. As a result, the divergence of an incompressible flow is always zero, as there is no spreading or convergence of fluid particles.
5. How is divergence used in fluid dynamics?
Divergence is an important concept in fluid dynamics as it helps us understand the behavior of fluid flow and its impact on surrounding objects. It is used in various equations, such as the continuity equation and the Navier-Stokes equations, to analyze and predict fluid flow patterns and behaviors.
  • Other Physics Topics
16K
  • Classical Physics
  • Mechanics
