What Is Electricity? Examples & Explanations
  • Thread starter steve102
  • Tags
    Electricity
In summary: US Supreme Court. Go read the US Supreme Court decision in the landmark case of TESLA v. MARCONI. In a unanimous decision, the Supreme Court said that "....the term 'electricity' shall be understood to cover electrical current and electrical charge...." (Prior to that decision, Marconi was the world's expert in radio, and Tesla wasn't too shabby either. Marconi got the Nobel Prize for radio. Tesla died broke; disputing what Marconi did with some of Tesla's patents. After the Supreme Court decision, Marconi had to pay Tesla royalties.)In summary, "electricity" is the
steve102
What is electricity? Let me use the example of turning on a light in a room.
I have been told that when I flip the switch, electrons flow in the wire at near the speed of light, and that is electricity.
I have also been told that electricity propagates as a field between the two wires, and the energy is in that field.
Further, I have heard of some phenomenon -- called drift current perhaps -- where there is a net accumulation or depletion of electrons in a wire over a period of a few seconds. Or, some propagation effect whereby electrons move only a few centimeters per second. Is there anything like this?
Thank you for considering my question.
This is incorrect, but close enough to the truth that it's often repeated. In fact, it is the electric field that propagates at near light speed, as you say in the next point:
This electric field actually does cause electrons to bounce around from atom to atom, but the net movement of any individual electron is actually rather slow (on the order of a few cm per second):
The net current comes from the aggregate movement of a great many (10^19 ish) of these electrons. As an analogy, think of a wave in water: a buoy wouldn't move much in the direction of the wave (nor do the individual water molecules), but the wave itself moves forward at great speed. So it is with electricity.
Another water analogy that I like: consider a water hose, already filled with water though none is flowing.
Somebody turns on the valve at one end of the hose. Almost instantly, water starts flowing out at the other end. Even though a given drop of water will take several seconds to travel the distance from the faucet to the open end.
And I say "almost instantly" because there is a short delay, due to the speed of sound in water, before the high pressure from opening the faucet propagates the entire length of the hose.
"Electron current" is the flow of conduction electrons in a conductor. "Conventional" curent, flow of positively charged current, is in the opposite direction. The direction of current was establiched long before electrons were discovered. The flow of current is based on the presence of a voltage, which creates an electric field along the conductor.
Power is essentially the product of current and an in-phase voltage Power (watts) = I times V.
The total circuit voltage is actually between the two conductors, one carrying the current, and the other carrying the return current. This voltage creates an electric field E between the two conductors. The currents create a magnetic field H around each current conductor. E and H are orthogonal to each other.
The total power flow can be represented by the vector cross product of E and H. The Poynting** vector, the vector showing both the amplitude and direction of the power, is
P = integral [E x H] dA, where A is the area of the surface between the two conductors where both E and H are non zero.
The Poynting representation of electromagnetic power flow is especially useful when the currents are not confined to conductors, like for example high frequency power in waveguides, or in free space near antennas.
** Named after John Henry Poynting
Ahem. Electricity is the effect obtained by turning the switch on, in the vernacular.
A Dictionary: The phenomena of electromagnetism. (Doesn't help much, does it?)
The stuff that moves in the wire isn't 'electricity'. It is current.
Electrons in wires don't travel at the speed of light. They travel more like the
speed of a minute hand on a clock! But let's back up a bit first.
What is electricity? That's easy. Just use the scientific definition, and ignore
the morass of incorrect and contradictory definitions used by the general public.
That's the traditional technique for cutting through the Physics Fog found in
popular culture. (Physics Phog?)
"Quantity of electricity" means quantity of Electric Charge. That's the MKS definition
of the word electricity. Amounts of "electricity" are measured in coulombs.
A flow of electricity is called an "electric current."
But if you adopt this definition, it creates certain problems when talking to
non-experts. In that case a battery becomes an "electricity pump" which
takes electricity in through one terminal and simultaneously spits it out the
other. The half-cell reactions at the surfaces of electrodes are pumping the
"electricity" through the electrolyte; through the battery, and back out again.
Similarly, an electric generator can never generate any electricity (it's just a
pump.) Also, electric companies don't sell electricity, and no electricity ever
travels from the utility plants to your home. Electricity only wiggles slightly
back and forth in any AC system. And if we use the scientific definition,
then "electricity" is not a form of energy. Coulombs and Joules are two
entirely separate things.
If we accept that "Quantity of electricity" means Charge, then we're in line
with Faraday, JC Maxwell, William Thompson, Einstein, and other heavy hitters.
In particular, in 1839 Faraday published a set of experiments which proved
that bioelectricity, triboelectricity, electrochemical electricity, and atmospheric
electricity were all exactly the same entity.
But later scientists stopped using this definition. They stopped using the word
Electricity and instead replaced it with the word Charge. Our contemporary experts
don't use any clear scientific definition of the word electricity, and they disagree
among themselves. But the original definition is still in the MKS standards
documents and in many physics refs (CRC handbook, for example.)
More about this whole topic:
Scientific definition of the word "Electricity"
http://amasci.com/miscon/maxwell.html
Is Electricity the charge, or is it the energy?
http://amasci.com/elect/elefaq1.html#ae
Electricity: list of definitions and their consequences
http://amasci.com/miscon/whatdef.html
Big list:
http://amasci.com/ele-edu.html
Try Beirce, Devil's Dictionary! Quite humerous. He actually figured it out.
The stuff that moves in wires is called "charge." An electric current is a flow of
charge, not a flow of "current." (And what is flowing in a river? is it the water, or
is it the current?)
1. What is electricity?
Electricity is a form of energy that results from the movement of charged particles, such as electrons. It is a fundamental force of nature and is responsible for powering many of the devices we use in our daily lives.
2. How does electricity work?
Electricity works by creating a flow of charged particles, typically electrons, through a conductor, such as a wire. This flow of particles creates an electric current which can be harnessed to power devices and perform work.
3. What are some examples of electricity?
Examples of electricity include lightning, which is a natural form of electricity caused by the movement of charged particles in the atmosphere, and the electrical power used to light our homes and run our appliances.
4. What are the different types of electricity?
There are two main types of electricity: static electricity and current electricity. Static electricity is the build-up of electric charge on an object, while current electricity is the flow of electric charge through a conductor.
5. How is electricity generated?
Electricity can be generated in several ways, including through the use of fossil fuels, such as coal and oil, which are burned to produce steam that turns turbines and generates electricity. It can also be generated through renewable sources, such as solar, wind, and hydro power.
  • Electrical Engineering
