clevermetal said:
Hi, new forumer here.
I've found this site a couple times before from google searches and whatnot but I've always been too scared to post here as everyone seems much too intelligent for my questions.
However I can't find a decent answer to this question, perhaps there isn't one, however I remain hopeful! Anyway, enough chitchat.
What is enthalpy?
I get that h = u + Pv
but when you're calculating heat added in a boiler or work done in a turbine it's always H2-H1 which leads me to believe it's the internal energy of the gas/vapour. But then that's U. So I'm confused as to what enthalpy actually IS
Cheers
please don't flame too hard, I'm only a second year undergraduate!
edit: my english skill is...well... lacking.
The enthalpy of a reaction is the "heat energy" given off by the reaction in a system
subject to an external pressure that is constant in time. When the pressure on a system is constant,
dH=TdS,
where dH is the change in enthalpy, dS is the
change in entropy, and T is the temperature. When the volume of a system is constant,
dU=T dS,
where dU is the change in internal energy.
The tricky part of this description is the word "heat". The word "heat" sometimes refers to energy transferred by conduction, sometimes refers to entropy transferred by conduction, and sometimes refers to the entropy that is created by an irreversible process.
The heat energy, dQ, of a reaction is,
dQ=T dS,
where
dQ is the "heat energy" that is either transferred or created,
dS is the
change in entropy,
T is the temperature of the system.
The problem is that Q is ambiguously defined. "Q" varies with the schedule of
heating even in reversible reactions. However, "S" is an equation of state. Therefore, "S" is always unambiguous when the reaction is reversible. Note that entropy can either be transferred or created, it can not be destroyed.
On the more practical side, the heat energy in a bomb calorimeter is the energy that leaves the container (i.e., the system) by conduction after a reaction has taken place. The heat energy of the bomb calorimeter is always equal to TdS. However, there is a difference in the heat energy depending on whether the contents of the container is kept at a constant temperature or a constant pressure.
The enthalpy (dH) is the heat energy given off by a reaction in a bomb calorimeter when the pressure on the system is kept constant. The internal energy (dU) is the heat given of by a reaction in a bomb calorimeter when the volume of the system is kept constant.
Very often, a system of interest is either kept at constant volume or kept at constant pressure. For most reactions, the two values (dH and dU) are different. However, they (dH and dU) can sometimes be the same.
Be careful around the word "heat" or the phrase "heat energy". They are deceptive. The dictionaries say that "heat" is a form of energy. However, there is no form of energy that can be unambiguously defined as heat. The least ambiguous definition of heat energy is,
dQ=T dS.
Heat is not always infrared energy. Heat is not always the kinetic energy of a molecule. Heat is not always vibrational energy. Heat is always,
dQ=T dS.
Entropy is the well-defined concept. Not heat energy.
