Is Short Communication Appropriate for Mathematical Analysis Revisions?
To address a mathematical error found in a published paper, the first step is to consider how to propose a revision. If the error is in one's own work, submitting an erratum to the journal is appropriate. For correcting someone else's mistake, a "Comment" can be submitted, allowing the original authors to respond. It's advisable to first contact the authors directly to discuss the issue, as this can lead to collaboration or corrections without public confrontation. If the error is significant, a formal comment may be warranted, but the author should verify the journal's submission guidelines for comments. Journals vary in their policies, so checking the editorial page for specific instructions is essential. If the authors are receptive, they might invite co-authorship on a revised paper.
blue_leaf77
So I noticed a mistake in the mathematical analysis in a paper and I want to propose the revised version. What should I do?
I think it doesn't worth a journal since the revision probably only takes a page. Is there other ways of doing such revision? I have heard there is this short communications thing, is this relevant? If it is, how long is typical short communication?
If you are correcting your own work, you can submit an erratum to the journal.
If you are correcting somebody else's mistake, you can submit a "Comment." If it is simply a typo, the original author may be allowed to submit an erratum, thanking you for your help, etc.
I believe that the "gentlemanly" thing to do is to first send a brief note to the authors of the original publication, which gives them the chance to fix little problems. I did this to a big wig when I was in graduate school, and was sent a very nice thank you letter from the big wig.
If it is a bigger problem (i.e. the analysis is wrong) the original author may get testy, and if you believe that you are correct, you can try the "Comment" route. Journals will allow the original author to submit a "Reply" to the comment. Sometimes you see a Reply to the Reply, etc.
I would try corresponding with the original author first. You may have made a mistake, and in being corrected you can learn something. Or you can endear yourselves to someone for helping them to remove an embarrassment from the literature.
Different Journals have different rules. You can look at the editorial page of the particular journal to see how to submit a Comment.
I simply disagree with the way they present the mathematical analysis. The reason is that their math analysis leads to a physical result which contradicts the underlying theorem. It seems to me that they didn't notice that discrepancy. I think I should sent e-mail to them first, but by the way where can I find this comment field. I opened the publication link but couldn't find it.
Yes this sounds like a bigger problem. If you write to them first, they may invite you to co-author a paper with corrections (assuming that you are correct).
Usually it is with editorial information. In PRL, it is in the "Authors" section:
http://journals.aps.org/prl/authors/comments-physical-review-letters
Ok thank you very much for the information.
After a year of thought, I decided to adjust my ratio for applying the US/EU(+UK) schools. I mostly focused on the US schools before, but things are getting complex and I found out that Europe is also a good place to study. I found some institutes that have professors with similar interests. But gaining the information is much harder than US schools (like you have to contact professors in advance etc). For your information, I have B.S. in engineering (low GPA: 3.2/4.0) in Asia - one SCI...
Bit Britain-specific but I was wondering, what's the best path to take for A-Levels out of the following (I know Y10 seems a bit early to be thinking about A-levels, but my choice will impact what I do this year/ in y11) I (almost) definitely want to do physics at University - so keep that in mind... The subjects that I'm almost definitely going to take are Maths, Further Maths and Physics, and I'm taking a fast track programme which means that I'll be taking AS computer science at the end...
I graduated with a BSc in Physics in 2020. Since there were limited opportunities in my country (mostly teaching), I decided to improve my programming skills and began working in IT, first as a software engineer and later as a quality assurance engineer, where I’ve now spent about 3 years. While this career path has provided financial stability, I’ve realized that my excitement and passion aren’t really there, unlike what I felt when studying or doing research in physics. Working in IT...
