What is Spin in Chemistry and Why is it Important?
Spin in chemistry is a fundamental property that explains the limitation on electron occupancy in orbitals, as no two electrons can share the same quantum numbers. The concept of spin is linked to the magnetic behavior of particles, where electrons exhibit a magnetic moment due to their spin, influencing their interactions in magnetic fields. Spin values are quantized, typically as rational numbers like ±1/2 for fermions, which is essential for adhering to the Pauli exclusion principle. This quantization arises from the requirement that particles must complete full wave cycles, leading to specific allowed spin states. Understanding spin is crucial for comprehending electron behavior in atoms and the underlying principles of quantum mechanics.
Atomos
In chemistry, we deal with spin to explain why there is a limit to the number of electrons that can occupy an orbital, ie. no two electrons can have the same quantum numbers. We are not required to know much more than that. But I am curious, what is spin? My chemistry book explained an experiment where hydrogen was passed through a magnetic field and half of the atoms were attracted to one side, and the other half where attracted to the other. So does spinning charge induce a magnetic field? Is that why electrons are said to have spin?
Also, if that is so, and two electrons with opposing spin occupy the same area, should not they attract each other since that have opposite poles?
And why are spin of particles always simple rational numbers, why are there no 3/12344 spins?
(Maybe the admin should move this to QM.)
I can say a little about spin...
At first there was a classical idea about the electron actually spinning I think. You can certainly draw a lot of analogs between classical spinning and the quantum spin, which is why it's called "spin". However, that analogy breaks down and we really can't say that the particles spin. It's better just to consider it as a certain quantum property.
Spin does yield a certain magnetic moment, which causes particles to behave in certain ways in magnetic fields, like you said.
I don't know if there is an answer to why certain particles only have certain spin states.
Atomos,
You might be thinking of magnetic monopoles which haven't been discovered yet?
Hmm can't edit... oh well...
Actually, after thinking about it, there are multiple reasons why the spin is always n/2.
You can simply talk about spin values (lower case cursive L) with respect to the number of states a particle can be in ('m'). From that you can see one reason why all spin states are L= n/2 (they simply derive from how many possible states the particle can be in). (n=0,1,2,3,etc)
Though there are some more complex quantum derivations.
it has to make a full wave , spin is +/- 1/2 because an electron is a fermion. the 1/2 means that in order to return full swing back to their current state they have to make 2 revolutions (2 actual spins) ... now, Pauli exclusion tells us that +/- 1/2 is key because no 2 electrons can have the same quantum numbers, since spin is a quantum number, then we would require a way to differentiate between 2 electrons in with the same n, l and m_l values...
Now, the following I'm not sure is correct or not, but its how I kinda got the 'jist' of it the first time I was in a room when it was taught (by a very bad teacher) ... the reason WHY one electron takes a +1/2 and the next in the orbital takes (2px for example) takes a -1/2 is because the energy required to have the same magnetic north as the first electron in the orbital makes it impossible for the electron to be in that orbital. Now, I've never confirmed or disproved this, and I kind of just accept the fact that the electron, which doesn't actually have a structure or anything ... , does have 'spin' , because a lot of people that are a lot smarter than me have tried to disprove it, confirm it etc.. and it has held 'firm' ...edit: about the nice numbers of spin, you really need to think about the way waves go ... if you had the 3/pi spin or something then it would take multiple movements around a circle just to get back to the original state, the 'nice numbers' can best be seen by looking at standing waves, and 'wrapping' one around a circle .. the circle representing not the e-'s path, but instead more like the % of the path it has gone ...
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
