What is the amplitude of induced EMF in a magnetic dipole antenna?
The discussion focuses on calculating the amplitude of induced EMF in a magnetic dipole antenna and an electric dipole antenna. For the magnetic dipole antenna, the relevant formula involves the change in magnetic flux over time, factoring in the frequency and area of the coil. The participants clarify that the correct approach requires including the angular frequency in the calculations. For the electric dipole antenna, the EMF can be determined using the electric field amplitude and the length of the antenna. Overall, the emphasis is on applying the correct equations and understanding the phase shift in the results.
midgic
1. A magnetic dipole antenna is used to detect an electromagnetic wave. The antenna is a coil of 50 turns with radius 5.0 cm. The EM wave has frequency 870 kHz, electric field amplitude 0.50 V/m, and magnetic field amplitude 1.7 X 10-9 T.
(b) Assuming it is aligned correctly, what is the amplitude of the induced emf in the coil? (Since the wavelength of this wave is much larger than 5.0 cm, it can be assumed that at any instant the fields are uniform within the coil.)
(c) What is the amplitude of the emf induced in an electric dipole antenna of length 5.0 cm aligned with the electric field of the wave?
(b) $$emf = -N\frac{\Delta \Phi}{\Delta t}$$
$$\Phi = B \times A$$
(c) ?
(b) The frequency is 870 kHz, so one oscillation takes a time of $$1.15\times 10^{-6}~s$$
$$\frac{\Delta \Phi}{\Delta t}= \frac{\Delta B}{\Delta t}~\times A = \frac{(2)(1.7\times 10^{-9}~T)}{(\frac{1}{2})(1.15\times 10^{-6}~s)}~\times \pi~(0.050~m)^2$$
Would this be the way to find $$\frac{\Delta \Phi}{\Delta t}$$
(c) I'm not sure where to start.
Thanks for your help.
Likes Delta2
For ## \frac{\Delta{\Phi}}{\Delta t}##, ## B=B_o \cos(\omega t) ##, so that ## \frac{dB}{dt}=-\omega \sin(\omega t) =\omega \cos(\omega t+\pi/2) ##, where ## \omega=2 \pi f ##. The factor ## \omega ## is the correct factor to use here. Using ## f=\frac{1}{T} ## will be missing the ## 2 \pi ## factor. ## \\ ## And (c) is simple. You just need to convert ## L=5.0## cm to meters. They give you the electric field ## E ## for the electromagnetic wave. The EMF for that case is ## \mathcal{E}=\int E \cdot dl=E L ##.
Likes Delta2 and midgic
Thank you so much for your reply. That makes sense for part (b).
I think I can write it like this: (?)
$$B = B_0~cos(\omega~t)$$
$$\frac{dB}{dt} = -B_0~\omega~sin(\omega~t)$$
Then $$emf = -N~B_0~(2\pi~f) \times \pi~r^2$$
And for part (c)...well as you point out, that's quite straight-forward. I should have been able to do that one.
Thanks very much for your help.
Likes Delta2 and Charles Link
They just want the amplitude for part (b) so don't include the minus sign in the answer for the amplitude of the EMF. The minus sign is just the result of a phase shift.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
