What is the angular speed of a ball sliding on a rotating ring at a given angle?
The discussion centers on calculating the angular speed of a ball sliding on a rotating ring at an angle of θ = π/4. The initial angular speed of the ring is denoted as ω₀. By applying the conservation of angular momentum, the final angular speed (ω₂) is derived as ω₂ = (M/(M+m))ω₁ when substituting θ = 45 degrees. The inertia contributions from both the ring and the ball are considered, confirming that angular momentum remains conserved throughout the motion.
  • Understanding of angular momentum conservation principles.
  • Familiarity with rotational dynamics and inertia calculations.
  • Knowledge of the parallel axis theorem in physics.
  • Basic trigonometry, particularly sine functions for angle calculations.
  • Study the conservation of angular momentum in non-conservative systems.
  • Explore the parallel axis theorem and its applications in rotational motion.
  • Learn about the dynamics of rigid body rotation and moment of inertia.
  • Investigate the effects of frictionless surfaces on motion in rotating systems.
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of rotating systems and angular momentum conservation.
valandil
A thin ring of mass M and radius R rotates around its vertical axis. A small ball of mass m can slide, without constraint nor friction, on the ring. If the angular speed of the ring when the ball is at the top is [\tex]\omega_0[\tex], what is the angular speed when the ball is at [tex]\theta=\pi/4[/tex].
This is what I can't find. The problem seems easy enough, provided the right path of solution.
I tried working with the angular momentum conservation law. That gives:
[tex]L = I\omega[/tex]
where
[tex]I= MR^2[/tex]
The contribution of the ball to the inertia is null, because it is on the axis of rotation at that instant. Hence, we have
[tex]\omega_0 = \frac{L}{MR^2}[/tex]
However, if we include a dependence on [tex]\theta[/tex], we obtain
[tex]L = (I_{ring} + I_{ball})\omega[/tex]
[tex]L = (MR^2 + mR^2\sin^2\theta)\omega[/tex]
Now, that seems bad to me, because (1) it's a bad application of the parallel axes theorem because I can't write the inertia of the ball relative to the center of mass since I do not have its radius and (2) it does give an answer as a fraction of the initial angular speed.
Any ideas?
Since there is no net external torque on the system, angular momentum is conserved
apply conservation of angular momentum.
initially L= {(MR^2)/2}w1 (applying perpendicular axis theorem)
finally, L = {MR^2 + mR^2sin^2(theta)}w2
substitute theta=45
and you get w2= M/(M+m) w1
Thank you. I just arrived at the same solution.
18K
  • · Replies 17 ·
  • · Replies 59 ·
  • · Replies 31 ·
