What is the common velocity of the arrow
  • Thread starter Thread starter missmerisha
    Velocity
The problem involves an arrow of mass 100 g and an apple of mass 80 g, with the arrow initially traveling at 40 m/s. Upon impact, the arrow and apple stick together, requiring the calculation of their common velocity post-collision using the conservation of momentum principle. The initial momentum of the arrow is calculated as 4 kg·m/s, and the momentum after impact must equal this value. The correct equation for the combined mass after the collision is (0.1 + 0.08)v = 4, leading to a common velocity of approximately 22 m/s. The confusion arises from misapplying the momentum conservation equation, emphasizing the importance of correctly accounting for the combined mass.
missmerisha
An arrow of mass 100 g is fired with an initial horizontal velocity of 40 m s–1 to the right at an apple of mass 80 g that is initially at rest on a horizontal surface. When the arrow strikes the apple, the two objects stick together. What is the common velocity of the arrow and apple after the impact?
Momentum = mass * velocity
Initial Momentum of the Arrow
p=m*v
=(.1)(40)
= 4
4=.08* v
therefore v= 50 m/s
the answer says it's 22m/s
4=.08* v
therefore v= 50 m/s
This is wrong.
So rewrite the above equation.
I don't get it
If the momentum is 0 then the velocity is 0
Momentum after impact = ( 0.1 + 0.08)*v
m1v1 = (m1 + m2)v
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
