What is the definition of angle?
In summary, the concept of angles remains undefined in both Physics and Mathematics books despite being a dimensionless quantity. This raises the question of why temperature has a definition while angles do not. However, it is possible to define angles without using the word themselves, as discussed in a PF Insights article and forum discussion. Additionally, when two angles intersect, their values can be added or subtracted, and the value of an angle at the intersection of its two rays is either 0 or 2pi, depending on the direction of rotation.
Coder Hashtag
TL;DR Summary
Till date, no Physics or Mathematics book in the world does contain the definition of our most favorite notation - theta. Though it is a dimension less quantity, why can't it be defined when temperature has a definition? Let's check out. And most importantly, it needs to be defined without using the word twice in the definition.
An angle is the area created between two lines crossing on the plane.
  • Sad
Likes berkeman
But does it at all match with the dimensions of area?
Coder Hashtag said:
Summary: Till date, no Physics or Mathematics book in the world does contain the definition of our most favorite notation - theta. Though it is a dimension less quantity, why can't it be defined when temperature has a definition? Let's check out. And most importantly, it needs to be defined without using the word twice in the definition.
try -- https://www.mathopenref.com/angle.html
I would add to the above that an angle has a numerical scalar value, and when two angles are aligned such that the vertices intersect, and one ray of each angle intersects, then the value of the angle formed by the common vertex and the other two rays is the sum or difference of the values of the angles of the two original angles. Also, the value of an angle where the two rays intersect is either 0 or 2pi, depending on which way you go around. (If you have two rays in a plane intersecting at a vertex, you have both an inner and outer angle, since the rays split the plane into two sides. These are different angles, so it needs to be specified.)
There should be a more concise way of saying that.
1. What is an angle?
An angle is a geometric figure formed by two rays or lines that share a common endpoint, known as the vertex. It is typically measured in degrees or radians and is used to describe the amount of rotation between the two rays.
2. How is an angle measured?
An angle is measured by determining the amount of rotation between the two rays that form it. This can be done using a protractor, which is a tool specifically designed for measuring angles. The unit of measurement for angles is degrees, with a full rotation being 360 degrees.
3. What is the difference between acute, obtuse, and right angles?
An acute angle is one that measures less than 90 degrees, while an obtuse angle measures more than 90 degrees but less than 180 degrees. A right angle measures exactly 90 degrees and is often represented by a small square at the vertex of the angle.
4. Can an angle be greater than 360 degrees?
Yes, an angle can be greater than 360 degrees. This is known as a reflex angle and measures between 180 and 360 degrees. It is often represented by an arc connecting the two rays instead of a small square at the vertex.
5. How are angles used in real life?
Angles are used in a variety of real-life situations, such as in navigation, engineering, and construction. They are also used in everyday activities like reading a clock or measuring the height of a building. Understanding angles is important for many fields of science and mathematics.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
