What is the definition of the electric field according to Purcell's textbook?
The discussion revolves around the definition of the electric field as presented in Purcell's textbook, emphasizing that the electric field E is defined by the forces exerted by a fixed arrangement of charges on a test charge q0. It clarifies that the charges must be stationary to avoid influencing each other and to accurately measure the electric field without interference from movement. The critique of the common definition involving the limit of F/q0 as q0 approaches zero is highlighted, noting that this is problematic since charges smaller than the elementary charge e have never been observed. The conversation also touches on the implications of moving charges, which would create a magnetic field, and the necessity for the test charge to be effectively a point charge for proper definition of the electric field. Overall, the participants seek clarity on the conditions under which the electric field is defined and the role of test charges in this context.
y.moghadamnia
hi there
I have been studying Purcell textbook and I think I have some trouble understanding the E dfinition it gives.
ok first of all when it starts to define it, it says :"suppose we have some arrangment of charges fixed in space". so they don't move at all.
then it says "we are not interested in the forces these carges exert on one another but only in their effect on some other charge q0, {as a test charge}".
so the definition for E will be to add up all the coloumb forces the fixed charges have on the q0.
so then E is "another way of describing the systemof charges, by giving the force per unit charge in magnitude and directionm that an exploring charge q0 would experience at any point". fine, understandable. but then it critisizes the definition some books give, that the limit of F/q0 while q0\rightarrow0, will be the definition for E. it says this definition is wrong because "we have never observed a chargesmaller than e" and q0 can never be zero. so if we "take the first one our definition of E, without refrence to a test charge, no problem arises and the charges need not be fixed."
now here is my question. we said we need to fix them because if we have the test charge around it might move them and the forces might be wrongly added. is that the ONLY reason we need to get them fixed? arent they going to create magnetic field if they accelerate? isn't that going to effect it too? and finally, what happens to transposition here?
the whole thing is mixed up in my head, so fix it if u can!
We need to fix them down so they don't repel each other. And so we can look at the E field produced by them being stationary. And yes if they started to move we would have a current and that would produce a B field .
I think they say as q->0 because that way the test charge does not push around the charges creating the field. If you could hold those charges still, then I think you do not need the q-> 0 constraint. Also, the test charge has to be (practically) a point charge to define the E field as a function of position.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
