What is the difference between centrifugal and centripetal forces?
  • Context: High School
  • Thread starter Thread starter gaboalonso
    Centrifugal Centripetal
The discussion centers around the concepts of centrifugal and centripetal forces, exploring their definitions, implications, and the confusion surrounding their effects in rotating systems. Participants share personal observations and theoretical understandings, questioning the relationship between these forces and gravity, particularly in the context of Earth's rotation.
  • Some participants define centripetal force as an attraction towards a rotating center, while centrifugal force is described as a pseudo-force that appears to push objects away from that center.
  • One participant notes personal observations from a merry-go-round, expressing confusion about why increased speed seems to push them away, contradicting the centripetal definition.
  • Another participant suggests that gravity provides the necessary centripetal force to keep objects on Earth, implying that without gravity, objects would be thrown off due to centrifugal effects.
  • There is a discussion about the nature of centrifugal force being an apparent force due to inertia, with some participants emphasizing that it is not a "real" force.
  • Some participants argue that if the Earth were to rotate at a high enough speed, it would not only throw objects off but could also lead to the planet's disintegration.
  • One participant raises a question about the cause of gravity, indicating uncertainty about its understanding and relationship to centripetal forces.
  • Another participant clarifies that the force acting on an object in circular motion is centripetal, while the centrifugal force is a result of the rotating frame of reference.
  • There is mention of Newton's third law in relation to the forces involved, with some participants cautioning against using the term "centrifugal" to avoid confusion with the pseudo-force.
Participants express differing views on the nature and implications of centrifugal and centripetal forces, with no consensus reached regarding their definitions or the relationship to gravity. The discussion remains unresolved with multiple competing perspectives presented.
Some participants highlight the complexity of the concepts, noting that definitions may vary and that the understanding of gravity and its relationship to centripetal forces is not fully settled. There are also references to personal experiences that may not align with theoretical expectations.
gaboalonso
Hi all.
This is not a homework question, I'm 33 and far away from homework. It is just a personal doubt. I've read a lot about these forces, even some answers from these forums but still can't make something out of them.
What I've read:
*Centripetal: a force that makes objects attracted to a rotating center.
*Centrifugal: a pseudo-force that makes objects go away from a rotating center.
This is what confuses me: in a merry-go-round the faster you gyrate, the greater the force to push you away from it (Centrifugal force). I have observed that personally when I was a kid. But the Centripetal definition states that it should be the other way around, and it isn't. So, if the Earth is rotating at a high speed, why aren't we thrown out of it?
-Gabriel.
The way I imagine it is that the centrifugal force is essentially caused by your inertia (which is trying to move you in a tangential straight line).
(I think this is why it's not a "real" force, it's just an "apparent force" that exists in a rotating perspective.)
The centripetal force is also greater. It's just that from the perspective of someone rotating on a merry-go-round, you only notice the centrifugal force.
Gravity provides more than the needed centripetal force to keep us rotating with it. (The excess force going towards our weight)
Thanks Nathanael! What I get from your reply is that if it wasn't for gravity, we would in fact be thrown out of the planet. So Earth's gravity is far greater than the Centrifugal force the Earth spin has on us.
I was under the idea that gravity was a product of centripetal forces, but it seems that is not the case.
So, we know the gravity constant for our planet, but, what causes it?
gaboalonso said:
Hi all.
What I've read:
-Gabriel.
Centripetal is not a particular kind of force, it's just a word to mean any force directed toward the center. So gravity is the centripetal force for the moon orbiting around the earth. But if you have a rock tied to the end of a string, and you're rotating it around, then the tension in the string is the centripetal force. If there isn't a centripetal force, then the object won't go in circles, it will fly off in a straight line.
Centrifugal force is not actually a force. It's an apparent, or "fictitious" force that seems to be pulling an object away from the center when the object is traveling in a circular path. In actuality, the object doesn't have anything pulling it away from the center. If you are twirling a rock on the end of a string, and you suddenly let go, the rock isn't going to fly radially outward; it's going to continue traveling in the same direction it was going, along the straight-line tangent to the circle.
If the Earth were not spinning at all, it would still attract us.
What causes gravity? That question is way beyond me. I'm not even sure if it's understood very well (I think that it's not, but perhaps it is).
I haven't studied General Relativity (Einstein's theory of gravity) but if you're interested in gravity, that would be the thing to study.
What exactly did you observe? The outwards acceleration in the rotating frame of reference is what the Centrifugal pseudo-force is accounting for.
If the Earth was rotating at high enough speed to throw us out, it would fall apart itself or rather had never formed a planet.
The merry-go-round applies a force on you to make you move in a circle. If it didn't you would move in a straight line. The force provided by the merry-go-round is a centripetal force and it acts towards the centre.
Newton third law (summarised on Wikipedia) states "When one body exerts a force on a second body, the second body simultaneously exerts a force equal in magnitude and opposite in direction on the first body." That equal and opposite force we call the centrifugal force.
On the surface Earths gravity provides a lot more centripetal force than is required to move in a circle (a circle that has a radius equal to that of the Earth at one revolution per day). To prove it if you jump off a cliff you don't stay at the same radius. Instead gravity pulls you towards the centre of the Earth tightening your radius.
The rotation of the Earth does have some effect. If you weigh yourself on scales you find you weigh less at the equator than at the poles. If I remember correctly the difference is only a few % because gravity is much stronger than necessary to keep you attached to the Earth's rotating surface.
The OP is explicitly asking about the centrifugal pseudo-force, which exists in rotating frames and is not subject to Newtons 3rd Law.
What you describe is a real-force acting on the second object, that provides the centripetal force. Even though this force can act "outwards", the consensus among mentors on PF is to avoid the "centrifugal" label, to avoid confusion with the pseudo-force described above.
gaboalonso said:
What I've read:
The only way I can imagine anyone being thrown off the Earth by natural means would be if you were unlucky enough to be sitting atop a volcano when it decided to pop its top---big time.
LOL one of the funniest posts in physicsforums xD.
Theoretically if there wasnt any gravity, still the force of friction could ve keep us on Earth unless ofcourse the Earth was rotating with very highspeed v such that mv^2/R>max friction. Ahhh but wait, no gravity no friction also...
But friction isn't centripetal? Wouldn't friction only accelerate you tangentially? (assuming horizontal surface and ignoring the fact that, as you said, no gravity means no friction)
So it could theoretically keep you moving with Earth briefly, but the ground would soon "curve away" from under your feet
That's how it seems to me at least
Yes you are right nathanael, friction at the surface of the Earth can be only tangential to the surface.
I think the main reason for the trouble that people have with the fugal / petal thing is that we do not directly experience either centrifugal force or gravity. What we actually do feel is the reaction due these forces on ourselves - through our feet or our body in a seat. We misinterpret the 'being thrown outwards' sensation and the pressure of our body as being the true description of what's happening. To get a better understanding, it seems to be necessary to chuck out the intuitive view and start from the 'pure' direction.
Is it really any different from what you experience undergoing linear acceleration? When a car accelerates you feel as if you are being pressed back into the seat when in reality there isn't anything pulling you backwards - perhaps we should we also be calling that a pseudo force? Oh wait..
Under what circumstances are you talking about?
Friction can certainly be centripetal depending on the physical system e.g. a bug moving around in a circle on a rough plane will obviously be subject to a friction that is centripetal.
I wouldn't disagree with that. However, we can be irrational and there are many other clues to tell us that the car is accelerating and we have 'learned' to cope with that situation, perhaps. Having said that, 'everyone' feels they are being 'thrown forward' when the brakes are applied. That's another situation in which we have to get formal and not go by instinct if we want to get it right.
gaboalonso said:
What I've read:
As you know, the centrifugal force is a by-product of the spinning motion of the merry-go-round. You are sitting in the merry-go-round, so you experience this outward (pseudo) force.
Viewed from the outside world, you are moving in a circular motion. Due to inertia, you have a tendency at each moment to continue in a straight line, which would mean flying off the merry-go-round. You don't fly off the merry-go-round because you're sitting on a horsey (or, if it's one of those self-powered carousels, you may be hanging on for dear life). The horsey (or your hanging on) is providing the inward centripetal force that keeps your path on a circle.
Simply put, the force of Earth's gravity is much stronger than the centrifugal force (which is just how we, in our "earth" frame of reference, experience our tendency to continue in a straight line).
To clarify this, fictitious centrifugal force is a caculated value of angular velocity and radius, ω^2 * r and is the apparent force as observed from within a rotating frame on any object, including an object outside the rotating frame. If the object is not moving with respect to the center of the rotating frame, then to an observer within the rotating frame, that object experiences an outwards psuedo centrifugal force = ω^2 * r and an inwards coriollis psuedo force of 2 ω^2 * r resuting in an apparent centripetal force of ω^2 * r.
If the observed object is at rest with respect to the rotating frame, then the apparent centrifugal force is opposed by some real centripetal force, the forces "cancel", and the object is not accelerating with respect to the rotating frame.
Fictitious centrifugal force could be considered to be similar to artificial gravity.
  • · Replies 22 ·
  • · Replies 32 ·
24K
9K
