What is the difference between DIN 915 and DIN 916 set screws?
  • Thread starter Thread starter baris45
    Difference Set
The primary difference between DIN 915 and DIN 916 set screws lies in their design and application. The DIN 915 set screw features a dog point, which is intended to fit into a prepared hole or slot on a shaft. In contrast, the DIN 916 set screw has a cup point that creates a circular dent to secure the screw to the shaft. This distinction affects their usage in various mechanical applications. Understanding these differences is crucial for selecting the appropriate set screw for specific tasks.
baris45
What is the difference between "Hexagon socket set screw with dog point DIN 915" and "Hexagon socket set screws with cup point DIN 916" about usage field?
Welcome to PF.
The dog point DIN 915 is designed to enter a prepared hole or slot in the shaft.
The cup point DIN 916 is designed to cut a circular dent and so lock to the shaft.
Likes berkeman, baris45 and Ranger Mike
I got it now exactly. Thank you so much for your attention.
Likes berkeman
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
