Automotive What is the Discrepancy in Engine Power Calculation for Toyota Prius?
  • Thread starter Thread starter eng/mahmoud
    Engine Power
The discussion revolves around a discrepancy in the power calculations for the Toyota Prius, where one user calculated the internal combustion engine (ICE) power to be 162.1 kW, while official specifications state it is only 73 kW. Participants questioned the basis of the user's calculations and whether they were derived from an official performance scenario. It was noted that the total power output of the Prius includes contributions from both the engine and electric motors. Ultimately, the user acknowledged finding the mistake in their calculations, indicating that they received helpful support from the community.
eng/mahmoud
hey guys ,
i really need your help :)
this my calculations on toyota prius model and when i calculate the IC engine power i found it equal 162.1 kw
when i open Toyota Prius Specifications i found it equal only 73 kw
i don't know where is the problem
please help me :confused:
[PLAIN]http://i41.tinypic.com/mkhoqs.jpg[/PLAIN]
Where are you getting your figures from?
What exactly is the question?
the power i get is 162 kw and this is suppose to be 73 kw as toyota engine
what is wrong with my calculation ?
Why is it supposed to be as the cars power output?
ie, How did you come up with that scenario.
Is it an official Toyota performance scenario, for the Prius?What you have shown is that a car that weighs nearly 1.8 tons cannot accelerate up a 1:5 hill at 0.18g at 60mph with the power output of a Prius. Which I would say is probably right.
Did you make up the scenario?
Total power available is obtained by adding the power from the engine and the power from the motors.
Thanks guys for helping me, I really appreciate such an efficient support but i find the mistake
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
