What is the effect of arranging two springs in series?
The discussion centers on the behavior of two springs arranged in series, specifically focusing on the equivalent spring constant when one spring has a significantly lower stiffness constant than the other. Participants explore the implications of this arrangement, including the effects of spring stiffness and initial lengths on the overall system behavior.
  • Some participants calculate the equivalent spring constant using the formula \(\frac{1}{k}=\frac{1}{k_1}+\frac{1}{k_2}\) and find it to be lower than the stiffness of the weaker spring, K1.
  • There is confusion about why the equivalent spring constant is less than K1, with some participants expecting it to be higher but still less than K2.
  • One participant suggests that the formula does not account for the initial lengths of the springs, raising questions about how to incorporate this factor into the analysis.
  • Another participant explains that the overall stiffness appears weaker because the force acting on the system is influenced by the weaker spring, which does not become stiffer when combined with a stronger spring.
  • Some participants propose that adding a stiffer spring in series should not reduce the overall stiffness, questioning the reasoning behind the observed results.
  • A quiz question is posed regarding the equivalent spring constant when two springs with identical stiffness values are arranged in series, prompting further exploration of the topic.
Participants express differing views on the relationship between the stiffness of individual springs and the overall system stiffness. There is no consensus on whether the equivalent spring constant should be greater than K1 when a stiffer spring is added in series, indicating ongoing debate and uncertainty.
Participants note that the initial lengths of the springs and their individual stiffness constants play a significant role in determining the overall behavior of the system, but these factors remain unresolved in the discussion.
chrom68
I have two springs arranged in series (remember circuit diagrams from physics class!).
One has a low stiffness constant (K1 = 5) and the other connected to it has a much higher contant (K2 = 100). According to the equation (as used in wikipedia):
[tex] \frac{1}{k}=\frac{1}{k_1}+\frac{1}{k_2}[/tex]
http://en.wikipedia.org/wiki/Hooke%27s_law"
Question 1)
Using this i get my equivalent spring constant to be K = 4.76, which is less than K1?
I don't understand why. I would expect the equivalent constant to be much higher (but less than K2=100).
Question2)
This formula doesn't consider the initial lengths of each spring. How could it do so?
Question 1)
Question2)
Probably best to draw the springs in their initial state, and then compressed under some force. You should be able to derive the equation based on that.
The overall K will be lower than the weaker K, because your force "sees" the weaker K, plus some additional compression beyond what just the weaker K offers. Thus, the overall K appears a bit weaker than the weaker K. Make sense?
Imagine you have a very soft spring and a very hard spring in series.
You haven't done anything to make the soft spring any harder so the overall stiffness can't be any more than the soft spring (imagine attaching the soft spring to an infinite stiffness rod).
But you have added a strong spring which will give a little (however small) and so the overall system must have a little more give = overall stiffness must be less
I understand that the soft spring doesn't become any harder therefore shouldn't the overall stiffness still be greater than K1 (by just a small amount)? Surely adding a stiffer spring in series wouldn't make the stiffness weaker overall.
Draw the drawings I suggested in my post, and work through the numbers with some examples. What do you find?
Quiz Question -- what do you get for the composite K when you put two springs with identical K values in series? Why?
  • · Replies 27 ·
  • · Replies 21 ·
12K
  • · Replies 17 ·
