What is the equation of this curve?
  • Thread starter Thread starter phantomcow2
    Curve
phantomcow2
Let C be the circle with center (a/2, 0) and radius a/2. Let L be the line with equation x=a, find the polar equation of the curve produced in the following manner: FOr every angle \theta, -\pi/2 <\theta < \pi/2, consider the ray from the origin that makes the angle \theta with the positive x axis. This ray will intersect C at a point A and L at a point B. Let O be the origin. Then the point P on the ray is on the curve if line segment OP = line segment AB.
http://img341.imageshack.us/img341/8910/cireq.jpg
If I trace it out, which I did in my example, it begins to look like a centroid. However I don't know how to verify this. I'm not sure exactly how to systematically approach this problem.
My idea is to break the equation of the resulting curve into two parts: first the length of the segment from the origin to when it hits the boundary of the circle, then the distance from the circle to the vertical line; the resulting curve being the difference between the former and the latter. I believe the distance of the line segment from O to A is simply cos\theta. I'm not sure how I'd express the rest of it though.
Hints:
What is the equation of the line in polar coordinates: r1 = ?? in terms of θ?
What is the equation of the circle in polar coordinates: r2 = ?? in terms of θ?
Then your curve, in polar equations is r = r1 - r2.
The curve approaches x = a as a vertical asymptote.
Darn, it's been too long since I've learned about polar coordinates. I know that the equation of the circle in polar coordinates is r=acos\theta. Some research is needed to find a straight line!
Thanks very much for your assistance!
Okay, I looked through my old calculus books and have relearned that the equation of a vertical line is a=rcos(theta)
Resulting curve: acos(theta)-asec(theta)
Yes, but you mean r = a sec(theta) - a cos(theta)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
