What is the expression for the spectrum of a hot gas with Doppler broadening?
broegger
Hi,
A very hot gas is enclosed in an oven with a small window. The gas molecules emits radiation at a characteristic wavelength. I assume that because of the thermal motion of the molecules the emitted wavelengths will form a spectrum of some kind (Doppler broadening.) I am trying to derive an expression for this spectrum, but I don't know how... Any hints?
Thanks.
Yes. There would be no Doppler broadening for molecules moving parallel to the plane of the window. Molecules moving away would have red shift, and molecules moving toward the window would have a blue shift. The higher the temperature, the greater the range of velocities.
Maxwell-Boltzmann distribution - http://hyperphysics.phy-astr.gsu.edu/hbase/kinetic/kintem.html#c2
Like Astronuc said, you know the Doppler shift as a function of atomic velocity, and you know the distribution for atomic velocities. It's basically a change of variables.
I tried to perform the calculation of the spectrum.
I got the spectrum dP/df (power emitted each frequency unit):
dP/df = Pt >< dv/df >< fr(v)
Pt is the total power emitted by the gas, fr(v) is the Maxwell distribution regarding the radial component of speed (component in observer's direction), and v(f) is the inverse of f(v) which gives the doppler frequency as a function of the radial velocity.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
