What is the force needed to stretch a horizontal spring by 7.15 cm?
To calculate the force needed to stretch a spring by 7.15 cm, Hooke's Law (F = kx) is applied, where k is the spring constant (333 N/m) and x is the displacement (0.0715 m). The resulting force can be calculated as F = 333 N/m * 0.0715 m, leading to the required force. For the second part, when the spring is stretched to 2.88 cm, the acceleration of the mass can be determined using energy principles, considering both potential and kinetic energy. The potential energy of the spring at different displacements and the relationship between force, mass, and acceleration (F = ma) are crucial for solving the problem. Understanding these concepts will help in accurately addressing the homework assignment.
destro47
One end of a horizontal spring (k = 333 N/m) is attached to a 3.12 kg box, and the other end to a fixed, vertical wall. (A picture of this situation can be found in Fig 4-10 on page 102 of your textbook.)
a) Find the magnitude of the force needed to move the mass so the spring is stretched by 7.15 cm.
b) Suppose the spring is stretched 7.15 cm and released. When the spring is stretched by only 2.88 cm, what is the acceleration of the mass?
Tried it plugging in the given quantities into hookes equation, doesn't work out that way. How do I approach this one? Here is what I'm thinking so far:
F=ma
where F in this case is the same F in hookes equation, thus:
-kx= ma
Am I on the right track here?
You should be thinking in terms of energy, remember the potential energy of a spring displaced from equilibrium by a distance of x is 1/2*k*x^2
Also knowing that W=F*d, you can solve a)
Similarly for b) you start with all potential energy and at x=2.88 you have part potential and part kinetic, kinetic of course involves the speed, which you can solve for
EDIT: For a) I think I just solved for the force required to stretch the spring and you'd also have to add to that expression for w, so W=Wspring+Wmass, so the work done just displacing the spring + the work done just displacing the mass. I think
Sorry but my class has not covered W yet. I believe its W=fd, right? My professor is a real ball buster who genuinely enjoys making his students squirm over the homework assignments. Any other suggestions?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
