What is the frequency of the car's vibration
The discussion revolves around solving four physics problems related to vibration frequency, gravitational measurement, wave speed in strings, and timekeeping in varying temperatures. The first problem involves calculating the frequency of a car's vibration after it drops 1 cm due to added weight. Participants emphasize the importance of understanding simple harmonic motion (SHM) concepts to tackle these questions effectively. There is a call for collaborative problem-solving rather than simply providing answers, encouraging participants to engage with the material. Overall, the thread highlights the need for a deeper grasp of physics principles to address the posed challenges.
saltyload
Having trouble figuring out these 4 problems. I could use a walk through or an answer. thanks guys.
1a)When four people with a combined mass of 270 kg sit down in a car, they find that the car drops 1.00 cm lower on its springs. Then they get out of the car and bounce it up and down. What is the frequency of the car's vibration if its mass (when it is empty) is 2.0 103 kg?b)An astronaut on a small planet wishes to measure the local value of g by timing pulses traveling down a wire which has a large object suspended from it. Assume a wire of mass 4.00 g is 1.60 m long and has a 3.00 kg object suspended from it. A pulse requires 38.3 ms to traverse the length of the wire. Calculate gplanet from these data. (You may neglect the mass of the wire when calculating the tension in it.)c)A string is 41.0 cm long and has a mass of 3.00 g. A wave travels at 4.55 m/s along this string. A second string has the same length but one-fourth the mass of the first. If the two strings are under the same tension, what is the speed of a wave along the second string?d)An aluminum clock pendulum having a period of 1.80 s keeps perfect time at 20.0?C. When placed in a room at a temperature of -5?C, it will gain time. How much time will it gain or lose every hour?
3) For question d, I used the equation for thermal expansion and got the new length. Then I set up a proportion for 1.8/3600 = 1.794/x. It was wrong :(
We're more than happy to help you with your problems, but you're going to have to do some work yourself and we certainly won't give you any answers.
Let's start with the first question, which concepts do you think would apply here? Try reading your class notes on SHM and see if it helps.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
