What is the Initial Torque of a Rod with an Acting Force?
  • Thread starter Thread starter shiby4444
    Initial Torque
shiby4444
A rod is initially along the y-axis and has
length ℓ. A force F =ˆı F1 +ˆj F2 + ˆk F3
acts at the upper end of the rod.
What is the initial torque ~τ about the lower
end of the rod?
1. Zero
2. ˆıF3 ℓ
3. −(ˆı F3 +ˆj F2 + ˆk F1) ℓ
4. (ˆıF3 − ˆk F1) ℓ
5. (ˆıF1 +ˆj F2 +ˆk F3) ℓ
Hint: What's the definition of torque in terms of a cross product?
I am not sure. Please help
\vec{\tau} = \vec{r} \times \vec{F}
What answer would that be with respect to my choices?
That's for you to figure out! All I did was give a definition of torque. Hint: Find an expression for \vec{r} (its magnitude is ℓ) and perform the cross product.
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
