What Is the Jet Stream Wind Speed Affecting East-West Flight Durations?
  • Thread starter Thread starter jdlenner
    Airplane Flight
A scheduled flight of 2,700 miles is expected to take 50 minutes longer when traveling westward compared to eastward, with an airspeed of 600 mph. The discussion centers on the assumptions regarding the jet stream's wind velocity, which is typically considered to have a west-to-east component in the mid-latitudes of the northern hemisphere. The ground speed for eastward flights is increased by the jet stream's speed, while it is decreased for westward flights. Calculations suggest that the jet stream's wind component is likely around 60 mph. The initial confusion was attributed to an algebra error in the calculations.
jdlenner
A airplane flight at 2700 miles is schduled to take 50 min longer westward than eastward. THe airspeed is 600 m/hr.
What assumptions about the jet-stream wind velocity presumed to be east or west are made in preparing the schedule?
(what is the wind speed?)
I am going over Halliday and Resnick after more than 20 years(!) and this one is hanging me up. I would appreciate any help anyone here can offer.
Thanks
Thanks
The assumption would be that the jetstream has a west to east component of velocity rather than an east to west component, which is a reasonable assumption in the mid latitudes of the northern hemisphere (including USA).
Ground speed traveling east to west is air speed minus west to east compoment of jetstream speed. Ground speed traveling west to east is air speed plus west to east jetstream wind component. You should now be able to solve for the assumed west to east component of the jetstream speed. I haven't done the math, but it ought to be under 100mph. Gee, I had that Halliday and Resnick book 40 years ago!
HI,
Thanks for your response. As it turns out, it was just an algegra error on my part. "saving time" by doing all the steps in my head!
jdlenner said:
HI,
Yup, after i posted i tried to do the math and for some reason it was not that simple. Finally ended up with a jet stream wind component in the 60mph range.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
