What is the magnitude of the resultant of these two forces?
To find the magnitude of the resultant of two forces, 370 N at 11° and 293 N at 34°, the user calculated the x and y components of each force. The x-components were summed to 606.11 N, and the y-components to 234.44 N. The user then attempted to find the resultant by using the Pythagorean theorem on these sums. A suggestion was made to simplify calculations by choosing one force direction as the x-axis. The discussion emphasizes the importance of correctly calculating the resultant force in Newtons.
hammerbox
Two forces, 370 N at 11◦ and 293 N at 34◦ are
applied to a car in an effort to accelerate it.
3765 kg
370 N
11◦
293 N
34◦
these two forces?
Answer in units of N
I've tried find both xs of the forces using 370cos11=363.20 and 293cos34=242.91 adding them together to get 606.11, then I found the two ys using 370sin11=70.60 and 293sin34=163.84 adding them together to get 234.44. I then added the x^2 and y^2 of the two sums and square rooted them. What am I doing wrong?
Welcome to PF!
Hi hammerbox! Welcome to PF! :smile:
(have a degree: º and try using the X2 tag just above the Reply box :wink:)
3765 kg
370 N
11◦
293 N
34◦
these two forces?
Looks ok to me. :smile:
(btw, you could save a little time by using one of the force directions as your x direction … then you only have to look up cos23º and sin23º :wink:)
