What is the magnitude of the torque in this scenario?
  • Thread starter Thread starter BIOPSYCH
    Magnitude Torque
The torque generated by a force of F = (3.00 i - 2.00 j) N acting at position r = (1.00 i + 2.00 j) m is calculated using the cross product of the position and force vectors. The resulting torque vector is 0 i + 0 j - 8 k, leading to a magnitude of 8 N-m. The calculations confirm that the magnitude of the torque is correct, as derived from the equation T^2 = (Tx)^2 + (Ty)^2 + (Tz)^2. The final answer for the torque magnitude is 8 N-m. This demonstrates a successful application of torque principles in physics.
BIOPSYCH
A force of F = (3.00 i - 2.00 j) N acts at a location r = (1.00 i + 2.00 j) m on an object. What is the magnitude of the torque that this force applies about an axis through the origin perpendicular to the xy plane?
Torque is equal to the cross product of the position (vector r) and the Force (vector F).
I took the cross product and obtained 0 i + 0 j - 8 k.
Taking the magnitude, I found positive 8 m*N. Is this correct?
Looks good. (Although the units are traditionally written as N-m.)
the final equation that you've obtained was correct and also the magnitude of your vector is CORRECT. since the equation of getting the magnitude of the vector[the torque in particular] is:
T^2= (Tx)^2+(Ty)^2+(Tz)^2
so, by using the values you have there'
T^2= (0)^2+(0)^2+(-8)^2
T^2=(-8)^2
T=[squre root of](64)
T=8
good job.
