What is the meaning of a fundamental constant? Dimensioned or dimenionless
The discussion centers on the nature and significance of fundamental constants, particularly questioning whether dimensioned constants like Boltzmann's constant and the speed of light are more or less fundamental than dimensionless constants. Participants argue that dimensionless constants hold more meaning as they allow comparisons across different systems and are independent of unit choices, while dimensioned constants are seen as arbitrary definitions tied to human measurement systems. The conversation also touches on the implications of changing constants and how this relates to our understanding of physical laws, suggesting that constants like Boltzmann's k derive their relevance from the definitions of temperature rather than intrinsic physical properties. The use of natural units, where constants are set to one, is discussed as a method to simplify equations, although the concept of units remains essential for consistency. Ultimately, the dialogue emphasizes that while dimensioned constants are useful, dimensionless constants are considered more fundamental in defining the laws of physics.
nonequilibrium
So I was thinking about the question "What if Boltzmann's constant k were different?" but then I got thinking about the nature of the question.
What is the significance of a constant? Can you say one dimensioned constant is more fundamental than the other one? For example, I can imagine someone saying "c is more fundamental than the gas constant R" but does that have any meaning other than a personal liking for the speed of light?
"What if I change k?" Is that a well-defined question? Should I specify "If everything else stays the same"? And is that certainly non-contradictory? (For example how do I know if other constants are maybe defined using k?)
And it is often said that the real fundamental constants are the dimensionless ones. Why is this? I remember reading a quote that: any change in a dimensioned quantity is unnoticeable if it not accompanied with a change in a dimensionless quantity. If a dimensionless quantity changes, then certainly something measurable changes. Now why is this? And does this make it a more fundamental constant?
Also they say one can use natural units in which, for example, c = 1. I really CAN'T understand this: How can it NOT have a unit? If I then say v = 1/2, surely that is not correct? Is it not like saying "My bag weighs 2" and then assuming somebody will add the unit kg? For example if c = 1, it would be allowed to use the mathematical statement e^c = 1, but if I were to use a non-natural unit system, I would not be allowed to do that, because then I'd have a dimensioned exponent...
Any other comments about constants are welcome.
One last one: is there a fundamental difference in asking "What if k had a different value?" and "What if k could differ in different parts of our universe?" ?
In my view constants, fundamental or otherwise, are neither more nor less fundamental than dimensionless numbers - they are different.
Dimensionless numbers allow something not available with constants - they allow comparison of different systems.
The dimensionful constants are simply artifacts of our chice of units. The dimensionless constants are the ones that define physics. They are the ones which are independent of our choice of units.
Hm, I don't seem to get the difference. Aren't dimensionless constants artifacts of our choice of numeric system?
e^{i \pi} + 1 = 0
No, but their numeric values are. That's why they often retain symbol form.
the ratio of a circle's circumference to it's diameter is pi. It's not absolutely 3.14(etc...) that's just how we represent it in the base 10 number system.
As far as I understand, natural units were created to removed constants. For example, Einstein's E=mc^2 is simplified to E=m when using natural units (i.e Planck units).
The Boltzmann k has no real physical meaning. It's only used to defined the temperature unit. If you would define a temperature unit different from Kelvin, then Boltzmann k would change.
c doesn't have any real meaning either. It basically defines the unit of length.
Only dimensionless constants have a real meaning. All others only define what humans use for units.
In fact there are only two dimensionless number in classical physics which have some univeral relevance. One is the fine structure constant and the other a ratio for the gravitational constant.
But even those dimensionless constants might not be univeral. Recently there have been reports (again) that these dimensionless constants vary in the universe. But still there are the only ones with meaning, rather than being an arbitrary definition of mankind physical units.
You use different unit for length so that c comes out the numerical value 1. Then you drop the units which are the same in all equations anyway. Strictly speaking there still should be a unit. Especially if you don't want to lose the ability to make a check for unit consistency.
Surely Aliens *don't* use the same idea of assign temperature a scale such that water has the special temperatures 273 Kelvin and 373 Kelvin for melting and boiling. In such a case they'd get a different k.
Perhaps you'd care to expand on this statement?
I have a wall chart stuffed full of dimensionless numbers.
Which ones do you mean? Most of them are either arbitrary and related to the choice of human physical units, or they are related to a process which is derivable from more fundamental concepts.
For example, if I decide to have a scale different from Kelvin, then the numerical value of the Boltzman constant would change. It's really just arbitrary.
In classical physics there are only two constant. Namely the fine structure constants and the gravitational constant.
If you add particle physics you get bunch of constant more, but maybe one day these will be derived too:
http://math.ucr.edu/home/baez/constants.html
There are 154 dimensionless numbers on this chart - mainly related to fluid mechanics.
OK, but if it's related to fluid mechanics then is goes into the category "constants derivable from fundamental principles". Probably if you ever manage to solve Navier-Stokes, then you can find these constants. So it's rather a mathematical constant, like Feigenbaum's constant. It's not something that is "encoded into physical reality independently".
Perhaps you'd like to produce something more concrete than your say-so?
Do you actually read my posts? You should at least make an attempt to understand them.
Or if you want to read some authority's opinion then read John Baez.
I also recommend the Baez FAQ entry.
You can of course have an infinite number of dimensionless constants (α, α/2, α², sin(α), etc.). There are a much smaller number that are considered "fundamental". I think it would be difficult to make a case for any of the fluid-mechanics dimensionless numbers being "fundamental". Generally that label is reserved for the dimensionless constants that govern the simplest interactions we can study.
That is a good point: if I say "say c has a different value", it is not as clear as "say \frac{c}{\overline{T_E}} changes" with the numerator being the average period of the Earth around the sun: not coincidentally, this is a dimensionless "constant". Okay the numerator is not an actual constant, but it's the best I could find for a conceptual example.
But even those dimensionless constants might not be univeral. Recently there have been reports (again) that these dimensionless constants vary in the universe. But still there are the only ones with meaning, rather than being an arbitrary definition of mankind physical units.You use different unit for length so that c comes out the numerical value 1. Then you drop the units which are the same in all equations anyway. Strictly speaking there still should be a unit. Especially if you don't want to lose the ability to make a check for unit consistency.Surely Aliens *don't* use the same idea of assign temperature a scale such that water has the special temperatures 273 Kelvin and 373 Kelvin for melting and boiling. In such a case they'd get a different k.
Hm, of course the numerical value for our dimensioned constants depend on our choice of units, but when I mean "different k" surely I don't simply mean a different set of units. I've heard "k doesn't have a physical meaning, it's due to the definition of temperature" a lot of times, but I don't get its point. For example, as you say, the speed of light is also due to our defnition of meter and second (okay, in the new system it's the other way around, but that's not really important for this discussion), but the fact that in a certain system c has THAT value means something? Hypothetically, if I just look at a beam of light passing, it has THAT exact speed, its speed doesn't become something trivial, but is predetermined by nature, somehow. Why can't k be the same way? If k has to do with how we define temperature, namely using the trippelpoint of water, then k has a physical meaning having to do with the physical system of water in such an environment? I wonder if this in essence means one could derive k theoretically by modelling a system of water.
Two other remarks:
- Oh okay, so the units in a natural unit system are simply implicit? That solves that problem for me
- Which two dimensionless ones do you mean? I don't recognize the second one with a ratio of G with something else.
EDIT: I suppose a clearer example is changing the fundamental constant \frac{c_{''here''}}{c_{''there''}} = 1. This seems like a non-arbitrary well-defined question, once "here" and "there" are specified.
Imagine you are the first human and you haven't defined temperature units or measured Boltzmann constant yet. Now you can arbitrarily define one of them and the other will follow.
Just historically Kelvin was defined first as to make the water transition points 273 and 373. The Boltzmann constant follows from using thermometers defined this way.
Imagine you have no rulers. How would you proceed to gauge one? The only way is to
*define* the speed of light and use a fixed reference for seconds to create a unit for length.
Or what else?
Again historically the meter was defined to be a special length which was passed from generation to generation. At one point they noticed that this is arbitrary and instead they fixed the value of the speed of light determined with the current meter rule.
I once thought a lot about all kinds of natural units. Basically you can set many physical constants to have a numerical value one, just by picking the right units. However there is one constant that you cannot circumvent: all dimensionless combinations cannot be changed. One is the fine structure constant. The other is the gravitational constant divided by some other constants as to give a dimensionless number. I forgot which units you need for it, but maybe you can find out yourself :) [haven't got my notes here]
Candidates are the dielectric constant, speed of light, charge of electron, mass of electron and so on (maybe that's even enough).
Hm, the main thing I'm having trouble with is that it seems that you're saying that dimensioned constants are meaningless... Well okay they're meaningless on their own, if you don't know what the units are, but the process of defining units is choosing things in nature as to give meaning to the later derived constants. For example, go back to the old definition of meter and second, the ones not using c; I'll call them symbolically the "stick" and "drop" respectively. Okay once you had that, you could 'compare' the velocity of light with these units. You saw that in one drop, light passed about 300 million sticks. Okay if you had chosen another stick, you would've gotten another number, but it's precisely because the amount of sticks light passes depends on the definition of a stick, that light gets a physical significance: the fact the numerical value changes can be seen as nature nullifying your arbitrary choice of a stick. So I can't really follow when you say "c doesn't have any real meaning". Are there then parts of what I've said in this post that you don't agree with?
Maybe there is nothing I don't agree with.
I'll put in other words: There is no way an alien civilization could deduce our numeric value for the speed of light, because it depends on an arbitrary choice of meter.
However they could determine the fine structure constant, which is supposed to be universal (apart from recent claims)
And I fully agree with your last post. But then saying "k does not have a physical significance" seems unjustified, doesn't it? I think you'd agree the speed of light (not the numerical value) has a physica significance, so why shouldn't k? After all the reason you're using to call k that is also applicable to c, so if k does not have a physical significance, that can't be the reason.
It has the same significance as a cup for a volume measure. It's arbitrary, but you do need at least some reference, so you use the cup.
It's a matter of view I guess.
Yes I did indeed read your posts - and responded politely.
Furthermore when asked for further information I supplied it.
In turn I asked you for further information and received what appears to be a rude response.
I did not seek an opinion I asked for a chain of sold reasoning to back up statements, apparently plucked out of the air.
In particular you have stated that there are only 2 fundamental dimensionless numbers (I do not call them constants, which have a different definition in my dictionary).
Therefore I ask for a derivation of the
Knudsen Number from these two numbers.
I hold that this cannot be done, but will applaud if you demonstrate.
Just out of curiousity: what would you call a constant?
And a bit more on topic: I was wondering, I think everybody agrees that if you change a dimensionless constant that there would be a noticeable difference (at least in principle), but why must this be a physical constant? For example, if the ratio \frac{\textrm{distance that light travels in one second}}{\textrm{length of my forearm}} changed, surely that would be observable too?
Is it because the physics that makes up the length of my forearm can be traced down to physical constants, making it more a practical clarity issue to demand the ratio be one of physical constants. Or is it more fundamental why I can't use my forearm?
@Studiot: I wrote down well-defined reasoning. What's really rude is when someone is too lazy to spend a minute thinking about what people write and instead continuously nags it's just an opinion.
My first statement was "If you would define a temperature unit different from Kelvin, then Boltzmann k would change." and you'd do well searching for the next.
As I don't get the impression that you even try to understand what I wrote about derived constants, I feel no need to explain the difference to you again. The Knudsen Number is derived.
@Vodka: True, in the relation between speeds and lengths doesn't change. If there was something like a fixed length of universal forearms, then the ratio between lengths could be called a constant. I think there isn't such a length. But you may call the ratios of particle masses a constant maybe. So you are right. If you manage to find to related measures, then they are some kind of constant.
But are there any others than masses?
You clearly failed at your own hurdle not reading another's posts.
1) Nowhere in this thread have I discussed Kelvin and Boltzman.
2) Mr Vodka appears the only one who has noticed a distinction I drew about dimensionless numbers (such as Reynolds No) which is that they allows comparison of different systems not different systems of measurement as for instance setting c = 1 does. This importance of this facet is huge.
3) I have not seen, or do not know how, to derive Knudsens number from your two 'fundamental numbers - nor its seems can you.
I apologise to Mr Vodka that his very excellent question is being so debased when I tried to contribute to the discussion, and turned the other cheek several times to your jibes.
That's exactly your problem! I mention Kelvin and Boltzman and you have go by skipping this fact and calling out I haven't explained any facts.
Then think again. People can't even derive the most basic quantum mechanical problems, yet quantum mechanics is known to perfectly explain these problems.
Just because no-one has a computer powerful enough to derive all your number, doesn't mean they are not derivable.
Maybe you call "Perhaps you'd like to produce something more concrete than your say-so?" one of your cognitive highlights, where you contribute to the discussion. You admitted yourself that you didn't even think about Boltzmann when I wrote about it.
Gerenuk, enough of this nonsense. I will play no longer.
Mr Vodka.
Consider the ratio of two lengths. inches/millimetres. This is not a dimensionless number and can be rewritten with a true constant in the form
millimetres = 25.4 x inches
Here 25.4 is a true constant.
This constant allows us to compare measurement systems of length.
Other more exotic constants are always the same (non variable) when put into an equation. But that is the nature of a constant.
Now consider the ratio of inertial forces/viscous forces in a fluid. Measuring both forces in the same units results in the dimensionless Reynolds Number.
This is not a constant but can vary over a very large range.
However certain specific values of this number are critical in that they denote the change from laminar to turbulent flow.
Thus at a Re of 1400 an airflow will change from laminar to turbulent, as will a water flow, as will a flow of granular material such as sand or salt.
This variable dimensionless number allows us to compare (aspects of) different physical systems and make predictions about their behaviour.
Before this bickering gets any worse I recommend a brief visit to the following pages:
http://en.wikipedia.org/wiki/Dimensionless_physical_constant
From there, go where you will.
PS: I guess what is implicit in this is that constants relevant to many-body phenomena can be calculated (given "enough" computational power and time) from more fundamental things. There is, of course, the debate of reductionism versus emergence buried in some of that, but for the purpose of this thread, I think one can ignore that.
  • #31
Thank you for the links, Gokul. I did google J Baez but did not find these.
I also looked again at the title of this thread and realize that I was too hasty when reading it.
Mr Vodka only referred to constants, with or without dimensions, so my introducing variable dimensionless numbers was a bit off thread. It's just that the context I normally use dimensionless quantities is as I described.
Sorry for any confusion this has caused.
  • #32
k and c are "in the same boat". They both have the same physical significance, i.e. they tell you something about your choice of units. Because of the fact that through judicious choice of units you can make a dimensionful constant have any value there is simply no additional information in the constant. It is only when you make dimensionless comparisons that you start to gain any information about physics besides the choice of units.
For example, we might say that c is very fast. That is certainly the case if we are using anthropomorphic units like a second which is about the duration of a heartbeat and a meter which is about the height of a child. By c being large in such units we mean that in one heartbeat a pulse of light would go past many children laid head to foot. On the other hand we might use stellar units and say that c is very slow, e.g. if our unit of distance is some average distance between galactic groups and our unit of time is some average lifetime of a star. It all depends on our choice of units.
Here are a couple of links from a while back where I explored the idea of the physical significance of dimensionful vs. dimensionless numbers:
https://www.physicsforums.com/showpost.php?p=2011753&postcount=55
https://www.physicsforums.com/showpost.php?p=2015734&postcount=68
  • #33
Thank you for the replies.
Hm DaleSpam interesting two posts!
A few questions: (if you don't have time for them all, then I'm also happy if you could just look at question 3 :))
1) "So, basically we have just c doubling and the permittivity and permeability halving and no other changes." Well I suppose there could be more changes, right? Would it in principle suffice to check each of the dimensionless fundamental constants for a change?
2) So let's for a moment define meter as the length of a certain rod and a second in a similar way (earth's orbit or something). Now let L_c be the distance light travels in one second, expressed in meter. Now define \beta = \frac{L_c}{[L_c]}, then beta is a dimensionless number! It's equal to the amount of rods light passes in a certain fraction of Earth's orbit. What if say \beta' = 2 \beta? Surely this is an observational difference. So does that imply there must be a change in one of the 26(I think) fundamental dimensionless constants? I suppose it does, right? Because if it doesn't, then there wouldn't be an observational difference, although there certainly is. How do you know what dimensionless constants changed?
3) If I want to focus on changing k, does it mean that I have to find a dimensionless constant with k in it, so I know what has to change for it to be observable? The weird thing is, k has Kelvin as units (I mean, it has that unit in its unit), so there probably won't be any dimensionless constant for it! Unless N_A (Avog. number) = R/k can be seen as a dimensionless constant, but Baez didn't count it as one, and it might just be a definition? And if one argues "well then maybe k can't be involved in any observational difference", but surely that is wrong if we see PV = kNT => k = PV/NT. If I don't change the definitions involving the right hand side, then a change in k most definitely will be observational?
  • #34
A similar reasoning works for particle masses. However I think you cannot find a universal length to compare. Because there is no distinct special rod that you might describe to an alien "over the telephone". And also the orbit of a planet is derivable from just knowing particle positions and their arbitrary velocities.
So you're right for masses, but I guess one can't find an equivalent example for lengths.
  • #35
I don't see why this is an issue of universality... If I keep my rod, go to bed and overnight beta changes, then the next morning I can see the change by comparing my rod with L_c. I'm not interested in knowing if beta changed for aliens too.
  • #36
How would you define your rod? It's surely something like "it consists of so many atoms". But then the length is derivable again.
I mean you have to be able to communicate it to someone without actually handing over the rod. Otherwise the size of you cupboard would be called a universal constants, which doesn't make sense?
  • #37
I don't define the rod, it's just a certain rod I chose out and keep close.
Oh I see the problem: when the day after I compare L_c with the rod and it has changed, it might be because my rod has shrunk due to temperature difference? Can't we ignore things like that? (claim same environmental conditions)
  • #38
This notion is not what anyone would consider "fundamental". Fundamental means it's the same everywhere in the universe. Electrons have the same mass everywhere in the universe.
Personally, you might wish to redefine "fundamental" as to encompass the size of everyday object's length. Then absolutely everything will be a "fundamental" constant in your view.
But that's philosophical non-sense and does not yield any useful insights.
  • #39
The only useful way to define "fundamental" is by saying it's non-local and basically the same everywhere without me having to bring my sample rod.
This works for electron mass. I'm fairly sure aliens electrons weigh the same as on earth. So there are many of them. Not just a unique item.
  • #40
Well I wasn't claiming the rod to be fundamental, just a unit. I was basically talking about the fact that a certain (actual) fundamental constant expressed in a certan unit divided by that unit would be a dimensionless constant, and bringing that into the discussion "observational change <=> change in dimensionless constant"
But okay, I think I get your point: using units that are not universal is silly(?) So you'd like me to for example define a meter as x times the width of a hydrogen atom? That sounds universal. For that unit, a change in beta would imply a change in L_c divided by the Bohr radius, or equivalently a change in \frac{L_c m_e c \alpha}{h}, right? (I've used the idea of Bohr radius out of DaleSpam's posts he linked to)
Would it have made any difference if I had used the current definition of meter? I.e. in function of c?
  • #41
It's not silly. It's very practical.
But it has no deep physical meaning because it makes absolutely everything object in the world belong to what you call "universal".
If instead you restrict "universal" to measurements that can be "communicated over telephone", then you single out only very few numbers. If it's only so few, then maybe they have some special meaning.
You may use Bohr radius, but then you are basically referring to the constants in there.
  • #42
Yes. If there were some measurable change in physics and we checked all of the dimensionless fundamental constants and found them all unchanged then that would indicate at least one unknown fundamental dimensionless constant.
mr. vodka said:
2) So let's for a moment define meter as the length of a certain rod and a second in a similar way (earth's orbit or something). Now let L_c be the distance light travels in one second, expressed in meter. Now define \beta = \frac{L_c}{[L_c]}, then beta is a dimensionless number! It's equal to the amount of rods light passes in a certain fraction of Earth's orbit. What if say \beta&#039; = 2 \beta? Surely this is an observational difference. So does that imply there must be a change in one of the 26(I think) fundamental dimensionless constants? I suppose it does, right? Because if it doesn't, then there wouldn't be an observational difference, although there certainly is. How do you know what dimensionless constants changed?
You would have to measure each and see which had changed. The length of a rod is governed by the fine structure constant, and the radius of Earth's orbit is governed by the gravitational coupling constants, so those would be the first two to check. After that you would probably check the various mass ratios.
Yes, but I am not sure which dimensionless fundamental constants (if any) can be expressed in terms of k. I think that the dimensionless fundamental constant for k may in fact be Avogadro's number, but I am far from certain. It certainly was not included in Baez's list and I don't know if that is an oversight or deliberate.
  • #43
"Yes, but I am not sure which dimensionless fundamental constants (if any) can be expressed in terms of k. I think that the dimensionless fundamental constant for k may in fact be Avogadro's number, but I am far from certain. It certainly was not included in Baez's list and I don't know if that is an oversight or deliberate."
Oh shoot, N_A has a unit: 1/mol. Well \frac{R}{kN_A} = 1, but that doesn't look like a real fundamental constant due to it being exact...
Hm, I suppose the same trick as before is applicable: define \gamma := \frac{k}{[k]}, then gamma is a dimensionless universal constant, am I right? (as long as k is universal, which -I think- means "as long as water starts freezing at the same pressure and temperature everywhere"(?)). So if I change gamma, something in the dimensionless constants changes... Is it me or is what I'm doing fishy?
EDIT: in fact: if k is determined by choosing 273K to be the freezing temperature of water, then in essence shouldn't k be already in the fundamental laws that determine chemistry? If so then it would be contradictory to say "change k and keep all other constants the same"... But then again, I wonder if -somehow- you can't say the same for e.g. c, which would make the previous doubtful.
  • #44
That's not the right wording. Of course the boiling point of water is universal. But that is not the question.
k will be the same as long as you define your temperature scale (K) the same way. So k is purely a human invention. You could set k=14 J/X, then appropriately use X as your new unit of temperature, and the physics would be all the same.
It's the same as if the following scenario: You go to your garage and build a funky electronic device. When you spill water on it, it shows 15. You arbitrarily call the unit "Vodka". Now would 15 Vodka be qualified for a universal constant now?
I think it doesn't make much sense. But that's exactly what happened with k! Someone build a so-called thermometer for which he made up some *own units*. k only depends on this choice of units.
That's why k never appears in any dimensionless constants.
EDIT:
Hmm, or maybe another view is more appropriate! k is actually calculable! If only you could solve the quantum mechanics of boiling water, then you could calculate k. Right?
  • #45
I suspect that is correct and is probably why no dimensionless constants related to thermodynamics made Baez's list. In principle they are not fundamental, but simply due to the application of the fundamental rules to complicated systems. Similarly with the dimensionless constants in fluid mechanics.
  • #46
I'm surprised myself, but it's most probably true that k can in theory be calculated from the fine structure constant and the mass ratio of proton to electron alone.
  • #47
I disagree with Boltzmann's constant being calculable. I do agree that it is not fundamental. It is the constant of proportionality that converts temperature to thermal energy, E_{\text{thermal}} = 3/2 k T (for an ideal monatomic gas).
Some of the base units in the SI system are not really "base units" in the eyes of a physicist. Consider luminous intensity (SI unit=candela) and luminous flux (SI unit=lumen). Baez' list of fundamental constants does not contain anything that pertains to these units. These units relate a concept in physics (power) to human physiology (how the eye works). Temperature is, in a sense, another of those non-basic units. The basis for temperature is energy. If we instead measured temperature in units of joules/molecule or joules/mole there would be no need for Boltzmann's constant or the ideal gas constant.
Another way to look at it: Force used to be a base unit in and of itself. Remnants of this concept are still around: The English pound-force, for example. Newton's second law is F=ma in SI units but it is F=kma in English units. The k in F=kma is just a constant of proportionality based on an artificial rather than fundamental definition of units. (Note well: The k in F=kma is not Boltzmann's constant).
While the SI system did do away with force as a base unit (the Newton is instead a derived unit), it did not do away with all non-essential units. Temperature and luminosity remain in SI as units akin to the pound-force.
  • #48
I'm sure you can. I'll try to explain how.
I take melting and boiling water and put a gas thermometer in contact with it. I put a mark 273 and 373 on the gas thermometer. Next I take any experiment that yields the k. I simulate this experiment in the computer and calculate what will be the results and I'm done.
Refering to your example I would determine the numerical value of the temperature with my gas thermometer setup. I add the unit Kelvin to this number. Next I measure the velocity of the molecules in the gas thermometer. Therefore I can directly determine k.
OK?
EDIT: and I could do these experiments in a quantum mechanical simulator which only knows about the fine structure constant and atomic masses.
  • #49
I also agree that k has is derivable, of course! The value of k is basically determined by using the point where water freezes as a reference point. Surely such a point must be calculable out of the fundamentals. It's what I tried to say earlier with "in fact: if k is determined by choosing 273K to be the freezing temperature of water, then in essence shouldn't k be already in the fundamental laws that determine chemistry?"
But about k's (un)fundamental nature: but take for example charge: its unit can be put into a combination of L,T,M; so charge Coulomb is also a superfluous definition, isn't it? Yet we don't mind calling e fundamental. Okay, I don't know if the value of e is derivable even using only L,T,M; but the argument given was that T was a superfluous definition because we had energy, my point is that charge seems to be of the same category?
I also read an interesting paper where they said "mass" is a superfluous definition, making G the same status as k... (the author is called N V Studentsov, and it was published). A short quote out of it, of which I'm not entirely sure what it means:
The two coefficients of proportionality in Newton's laws may be equated to one, and then mass and force become derived physical quantities. Unit mass is the mass producing unit acceleration at unit distance. However [bla bla superfluous definition]
I admit it sounds like crackpottery on first sight, but the rest of the paper is really "sane" and professional (it's about the more general matter of defining constants for SI and other systems), so I believe what he says about mass must make sense.
  • #50
Yes, actually. You couldn't make aliens understand you value of e, because it depends on the choice of units. So as I said in the end only the fine structure constant is really fundamental. Morever, to my knowledge there is no theory yet, that can predict mass ratios.
Well, and going deeper into particle physics you probably get the other constants from Baez's lists.
Hmm, I wonder how much the value of one single particle is a fundamental. I could take two particles, let them attract and measure their velocity...
Hmm, just a thought...
