What is the minimum input voltage needed to turn on an NPN transistor?
  • Thread starter Thread starter TsAmE
    Npn
The minimum input voltage needed to turn on an NPN transistor is typically around 0.7V, which corresponds to the base-emitter voltage (Vbe). The discussion highlights that this value is often assumed for simplicity, but it can vary with temperature. There is a distinction between defining input voltage (Vin) as Vbe alone versus including the voltage drop across any series resistors, such as a 100k resistor. Before current flows through the resistor, it does not affect the voltage needed to turn on the transistor. Understanding these nuances is crucial for accurately analyzing transistor behavior in circuits.
TsAmE
What is the minimum input voltage for which the transistor will begin to turn on?
None.
I don't understand why the answer was 0.7V. I understand that yes by the time you reach the base there will be 0.7V left which will get dropped across the diode, but wouldn't Vin = 0.7 + voltage dropped across 100k?
Forgot to add the diagram
None.
That's a very good question. They must be defining "Vin" as Vbe, not including the 100k resistor. But you are correct, you could just as easily call Vin the input voltage to the 100k resistor, so it would include Vbe and Vrb.
BTW, you also know that the transistor's Vbe is temperature dependent, right? So it's not generally just 0.7V or 0.6V, although for many problems we just assume a set Vbe value.
It is in the wording of the question, too.
This means before there is any current flowing in the resistor and therefore before there is any voltage across it. Once current begins to flow, then the resistor limits the amount of current, but before then, the resistor has no effect.
In this diagram (below), which I produced yesterday from LTSpice for another thread, we are talking about the region near the origin (550mV, 0 µA).
The drop across a 100 K resistor with even 1 µA flowing is 0.1 Volt and you can see that the current at 580 mV is a lot less than 1 µA.
[PLAIN]http://dl.dropbox.com/u/4222062/Base%20emitter%20curve.PNG
Base current of a 2N2222 NPN transistor vs base-emitter voltage
Good point, vk6kro!
