What is the order of these functions
  • Thread starter Thread starter Gear2d
    Functions
The discussion centers on determining the Big O notation for the functions 2^x, 3^x, and 3^(x-10). Participants emphasize the need for clarity in defining "order" and the limits involved, particularly as x approaches infinity. They clarify that a function's order is relative and must be compared to another function, with specific attention to the relationships between f(x) = 2^x and g(x) = 3^x. The limit of the ratio of these functions as x approaches infinity indicates that 2^x is o(3^x), meaning it grows slower than 3^x. Overall, the conversation highlights the importance of precise definitions in analyzing function growth rates.
Gear2d
I need now what is the order (The Big Oh notation) of these three functions:
2^x
3^x
3^(x-10)
2^x
3^x
3^(x-10)
Your question is incomplete. You need to specify x ->?.
Also you should specify what your definition of "order" is. The "big Oh" I am familiar with says that one function is "O" of another function. Saying that g(x) is O(f(x)) (as x -> a) means that \lim_{x\rightarrow a} g(x)/f(x) is a finite number.
Often "order" is given in terms of x going to infinity but even so, your question makes no sense. A function does not just have an "order". It is or is not "O" of another function. Are you asking if 2x= O(3x) or vice-versa?
Good point guys. I wanted to compare two of them to each other, let's say:
f(x) = 2^x vs. g(x) = 3^x
now from this I have to determine if f=Theta(g), f<Theta(g) or f>Theta(g). Instead of using L'Hospital rule:
c=lim 2^x/3^x = lim (2/3)^x = 0 as x goes to infinite this would mean that f<Theta(g).
I wanted to do this using order where x>1. Would 2^x have O(2^x) and 3^x have O(3^x), where f(n)<g(n)?
Please don't shift from O(g) to "Theta(g)"!
And since that limit is 0, f(x)= o(g). "Small o" or f= o(g) means that the fraction f/g goest to 0. As I said before, most textbooks give: "f= O(g), as x goes to a" means that f(x)/g(x) goes to a finite limit" which includes 0 so if f(x)= o(g), it follows that f= O(g). Some textbooks however, require that f(x)/g(x) go to a [g]nonzero[/b] finite limit in order that f= O(g) so that does NOT include f= o(g). I recommend that you check the definition in your textbook to be certain which convention it uses.
Oh, and to answer your last question, f= O(f) for any function f so saying "2x= O(2x" (which is what I guess you mean by "2^x have O(2^x)) so "2x= O(2x)" is trivially true. A function doesn't have "an order" except as compared to some other function.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
