What is the physics behind radar
  • Thread starter Thread starter vetinoh
    Physics Radar
Radar operates on the principles of electromagnetic waves, utilizing the reflection of radio waves to detect objects. It sends out a pulse of radio waves that bounce off targets and return to the radar system, allowing for distance and speed measurement. The Doppler effect is also crucial, as it helps determine the velocity of moving objects by analyzing frequency changes in the returned waves. For foundational knowledge, resources like Wikipedia provide comprehensive overviews of radar technology. Engaging in forums can help clarify specific inquiries about radar physics.
vetinoh
what is the physics behind radar
Welcome to the PF. wikipedia.org can be a good place to start when seeking basic technical information:
http://en.wikipedia.org/wiki/Radar
If you have specific questions that come up in your reading and research on a subject, the PF is a good place to ask those specific questions.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
