What is the Probability and Risk Assessment for Motor Insurance Claims?
The discussion revolves around a motor insurance claims problem, focusing on hypothesis testing, probability calculations using Poisson and normal distributions, and risk assessment metrics. The original poster presents a multi-part question involving statistical analysis of claims data.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster attempts to formulate hypotheses for a significance test and questions the validity of their statistical reasoning. They express uncertainty about the normal approximation to the Poisson distribution and the implications of sample size on probability calculations. Participants raise questions about the correct interpretation of parameters and the formulation of hypotheses.
Participants are actively engaging with the original poster's attempts, providing clarifications on statistical concepts and questioning the assumptions made in the problem. There is a mix of interpretations regarding the parameters involved, and some guidance has been offered on the use of normal approximation.
There are indications of confusion regarding the parameters used in the calculations, particularly the meaning of "m" in the context of the Poisson distribution. The original poster also expresses uncertainty about the significance level and its application across different parts of the problem.
Samantha24
(a) A survey on 50 claims for a particular class of customers of a motor insurance company found out that the average cost for car damage is £700 with a standard deviation of 400. The insurance manager believes instead that the average cost is £80 bigger.
(i) Does the sample data suggest that the manager is right? Test at a 5% significance level the hypothesis that the average cost is £780. Specify: null hypothesis, alternative hypothesis, critical region and comment on the result of the test.
(b) For the same type of accidents, the number of claims per vehicle insured is known to follow a Poisson distribution with mean 0.03 per year. Using the normal approximation to the Poisson distribution, compute the probability that a group of 400 insured cars produces :
(i) Less than 10 claims per year.
(ii) More than 20 claims per year.
(c) Assuming the cost per claim is 780 with standard deviation of 400, claims’ frequency and portfolio’s size are as specified above:
(i) Compute the risk premium.
(ii) Compute the value at risk at 99.5% level for the Insurer losses.
For part (a) this is what I did;
H0 : m = 780
H1 : m = 700
From my test statistic I got 1.41. This is less than 1.96. So you don't reject null hypothesis. Also we can't conclude anything is statistically significant. Therefore, we can't tell if the manger is right or not.
For (b) I don't get what it means by Normal Approximation to the Poisson Distribution but this is what I did. Also I don't know if I should use the 5% significance level from before (If I did I could use the Poisson Table?).
(i)
P(X < 10) = P(0) + P(1) + .. + P(9)
To calculate each value I use: P(X)= (e^-m)*(m^x)/ x!
I don't know if I should be doing it like that or using the poisson table.. It doesn't seem to justify 4 marks..
(ii)
P(X > 20) = 1 - P(X < 20)
From here I use the same method as before but have many more values..? I'm sure there must be a short cut as for 4 marks each.. Seems like a lot of work.
Furthermore, what do I do with the 400? Does it just change my notation on my probabilities? I.e. P(X < 10, 400)?
For part (c)
(i)
RP = average cost per claim * probability of claims. So RP= 780*[the answer I get from (b)(ii)]
However, I don't know if my method of calculating in part (b)(ii) is correct, let alone (b)(i)..
Finally,
(ii) I'm completely lost..
Your expression for P(X < 10) is correct, but you need to say what "m" is in that expression (it is not necessarily the same as the previous "m"). By normal approximation to the Poisson we mean that under certain conditions, you can get quite good approximations to quantities like P(X < 10) by replacing the exact Poisson distribution by the normal distribution having the same mean and variance.
RGV
Yeah the m would be 0.03 there.
Does my part (a) seem correct? Since there are other ways to write the hypothesises?
No, m is NOT 0.03 in this question. You are not reading the question properly.
RGV
Oh.. m is 12..
  • · Replies 30 ·
  • · Replies 43 ·
