What is the relationship between instantaneous and average angular velocity?
  • Thread starter Thread starter Aristotle
    Curiousity
Instantaneous angular velocity represents the velocity at a specific moment, while average angular velocity is calculated over a broader time interval. Instantaneous velocity equals average velocity only when acceleration is constant; otherwise, they differ due to changing acceleration. When an object experiences varying angular acceleration, its velocity continuously changes, leading to a curved position versus time graph. An example illustrates that while average velocities can be calculated over intervals, instantaneous velocities are defined at specific points. The mean value theorem indicates that there will be a moment within the interval where instantaneous velocity matches the average.
Aristotle
Note that use of the homework template is mandatory in the homework forums.
Can somebody explain to me the reason why? Thanks!
Chances are your velocity was changing. The instantaneous = the average only when it is absolutely constant.
Say there was an object that was experiencing a varying angular acceleration decreasing over time to zero. Would that mean its velocity continues to increase/change over time?
The instantaneous is the average over an arbitrarily short time interval. In general, an average velocity can be over a substantial interval. In notation, d is used for an infinitesimal change, ##\Delta## for a general change. So ##\frac{\Delta x}{\Delta t}## is an average velocity over time ##\Delta t##, while ##\frac{dx}{dt}## is the instantaneous velocity.
If the acceleration is nonzero, then velocity is changing, regardless of whether the acceleration varies. It is only when acceleration = 0 that velocity is constant.
Ah I see. So because the velocity is changing over time, we get a curved position vs time graph (representing velocity) to show that its increasing. and so if we take the instant angular velocity at a single time it wouldn't equal with the average angular velocity (between two time intervals) because like you said, that velocity changes for every time, correct? Just wanted to make sure I follow what you're telling me.
Thanks!
It sounds like you've got it right.
I'll provide an example for you.
suppose you have velocities v=(1,2,3,4) at times t=(1,2,3,4)
the average velocity over the whole time is 2.5.
The average velocity over the first 3 seconds is 2.
The instantaneous velocities are only defined at a point, so for instance at t=4, the instantaneous velocity is 4.
make sense?
make sense?
Thanks you're the best!
Right, except there is certain to be some instant in the interval at which the instantaneous velocity equals the average over the interval (mean value theorem).
