What is the restriction for the sine function?
  • Thread starter Thread starter teng125
teng125
can anybody pls give me an example of this f(f^-1) = x??
thanx...
It's the definition of the inverse of a function f(x). For example, y = 2x and y^-1 = 1/2 x
how about if i want to write it using sin x??
Although I would say f(f-1(x))= x. You're missing the "x" on the left side!
"arcsine" is defined as the inverse of sine (that's why your calculator has them paired). sin(arcsin(x))= x.
There are "technical" problems. Since sin(x) is not "one-to-one" (sin(\pi)= 0= sin(0)) there can't be a true inverse (a function can't return both 0 and \pi for x= 0). What is normally done is restrict the sine function to x=0 to \pi (which is really a different function than sine defined for all x) so that arcsin returns the "principal value"- the value between 0 and \pi.
We don't really restrict sin function to x = 0 to \pi.
We, however, restrict sin function to x = -\frac{\pi}{2} to x = \frac{\pi}{2}. :)
Oops! It's cosine that is restricted to "between 0 and \pi!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
