What is the sweet spot for rotational kinematics?
The discussion revolves around a problem in rotational kinematics, specifically focusing on the concept of a 'sweet spot' related to a rotating object. Participants are exploring the dynamics of a rotating bar and its properties at different positions.
  • Participants are attempting to define the 'sweet spot' and its implications for the rotational motion. Some have calculated angular velocity and tangential velocity, while others are exploring the relationship between various parameters like distance and length in their expressions.
There is ongoing exploration of the problem with some participants providing expressions and relationships between variables. Guidance has been offered regarding the use of specific ratios in the equations, but no consensus has been reached on the overall approach or solution.
Participants are working under the constraints of a homework problem, with specific variables and relationships that need to be addressed in their solutions. The definition of the 'sweet spot' remains a point of contention and inquiry.
Pogorz
i've altered this image to be easier to read. ignore problem 1 except for the information given. the picture of the rotating object is for problem 2, which is the problem i need help with
http://img32.imageshack.us/img32/3690/screenshot20091121at931x.th.png
2. The attempt at a solution
i've solved for 'w' when the rotating bar is vertical, as well as velocity tangential. my issue is the whole 'sweet spot' definition.
You must have d, L and x=L/2 in your answer for v.
Hopefully the expression can be arranged so these appear together as d/L.
You are just asked to replace each d/L with Z.
I've attempted to solve the problem, found the centre of mass to be Xcm = (L+2d)/3. Not sure where to go from there, though.
Use your expression for the linear speed of the tip.
Replace every d/L with z.
  • · Replies 39 ·
  • · Replies 16 ·
  • · Replies 20 ·
