What is the velocity of the passenger relative to the water?
To determine the velocity of the passenger relative to the water, vector addition is necessary, combining the boat's velocity and the passenger's walking speed. The boat moves at 1.13 m/s, while the passenger walks up the stairs at 0.50 m/s at a 45° angle. The velocity vectors should be expressed in horizontal and vertical components for accurate calculation. A diagram illustrating these vectors can aid in visualizing the problem. The correct approach will yield both the magnitude and direction of the passenger's velocity relative to the water.
thschica
A passenger on a boat moving at 1.13 m/s on a still lake walks up a flight of stairs at a speed of 0.50 m/s, Fig. 3-44. The stairs are angled at 45° pointing in the direction of motion as shown. What is the velocity of the passenger relative to the water? :cry:
I have to get the magnitude of it and I get -123 which isfor sure not right
I also have to get the direction in degrees---- how do I do that.
My teacher hasn't taught us all of this yet!
It's best to draw a picture showing the velocity vectors. This is vector addition.
\vec{V}_{person/water} = \vec{V}_{person/boat} + \vec{V}_{boat/water}
Hint: express the velocity vectors in terms of vertical and horizontal components.
