What is this flux made out of?
  • Thread starter Thread starter THE 1
    Flux
The discussion centers on the composition and meaning of "flux," with participants clarifying its context. One participant explains that flux mathematically describes the strength of a field through a specific area. Another suggests the term might refer to welding flux, which is a chemical that purges impurities and promotes metal flow. The conversation ultimately focuses on magnetic flux, emphasizing the need for clarity regarding the term's application. Understanding the specific type of flux being referenced is crucial for accurate discussion.
THE 1
Does anyone actually know what this is made out of if indeed it is made out of something? Are there any theories?
What are you talking about? "Flux" of what?
flux is just a way of mathematically describing the strength of a field through an area (or volume, or whatever)
Unless, by chance, the question might refer to welding flux. That's a chemical used to purge impurities from a bead and promote the flow of metal.
Soz i mean magnetic flux
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
