What is torsional modulus, and where is it specified?
  • Thread starter Thread starter jamesson
    Modulus
Torsional modulus, denoted as G, is discussed in the context of its application in calculating minimum link length in lattice hinge design. The conversation highlights the confusion surrounding the definition and expected values of torsional modulus, particularly for materials like acrylic, where shear modulus is more commonly referenced. A participant calculated a value of 2.08 GPa for G, which is close to the known shear modulus of 1.7 GPa found in literature. The discussion suggests that the author of the original article may have used a slightly different shear modulus in their calculations. Torsional modulus is typically determined through torsion tests, relating shear stress to shear strain.
jamesson
TL;DR Summary
The attached site seems to use a quantity Torsional Modulus for which I cannot find neither the formal definition or a material spec
In the equation for minimum link length here
https://www.defproc.co.uk/analysis/lattice-hinge-design-choosing-torsional-stress/
he uses a quantity Torsional Modulus, denoted as G, which I cannot seem to find either a definition for or any kind of expected value. Shear modulus (also commonly denoted as G) is defined and published in multiple sources for the material he uses (acrylic). Google says it is 1.7GPa.
Now, from his description it seems fairly clear what he means by G and how he uses it. I tried to backsolve for G and this is what I got;
So, either my calculation is off or he's using some source I haven't found.
Thanks so much in advance for any assistance
Joe
PS - sorry if this belongs in materials, if so please let me know and I'll move it.
This must be the shear modulus. Your result is ##2.08 \ GPa## so not that far from value known from literature. Author of this article could have used slightly different shear modulus in his calculations than the value you’ve found in literature.
Thanks so much. What's your source for shear modulus, please?
It’s calculated through testing like young’s modules but instead of relating stress to strain the shear modules relates shear stress to shear strain through a torsion test. Most materials that are isotopic like steal had a young’s to shear modules relation, G=E/2(1+v) where v = poison ratio.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
