What is wrong with this diagonalization problem.
  • Thread starter Thread starter bluewhistled
    Diagonalization
The problem involves diagonalizing a matrix A, specifically finding an invertible matrix P and a diagonal matrix D such that D = P-1AP. The original poster expresses confusion regarding the presence of linearly dependent eigenvalues and their implications for diagonalization.
  • The original poster attempts to calculate the eigenvalues and expresses concern about the implications of having two identical eigenvalues. Some participants suggest checking for eigenvectors corresponding to each eigenvalue and exploring the concept of generalized eigenvectors.
The discussion includes various perspectives on the diagonalization process, with some participants providing guidance on the conditions for diagonalizability and the role of generalized eigenvectors. The original poster later indicates a resolution to their confusion regarding the eigenvectors.
Participants discuss the criteria for diagonalizability, including the relationship between the characteristic polynomial and the minimal polynomial, as well as the implications of having repeated eigenvalues.
bluewhistled
A is
[4 0 1
2 3 2
1 0 4]
Find an invertible P and a diagonal D so that D=P-1AP.
I keep getting two linearly dependent eigenvalues which means it's not diagonal but this problem doesn't state "If it can't be done explain why" or anything like that. So I just want to verify with some of you.
I subtract with LI and take the determinant and get:
(L-3)((L-4)^2 - 1)
(L-3)(L^2-8L+16)-(L-3)
L^3-8L^2+16L-3L^2+24L-48-L+3
L^3-11L^2+39L-45
Which I then factor out to be 5, 3, 3.
Am I doing something wrong/missing something?
The eigenvalues are correct. Now, did you plug each eigenvalue, one at a time, into your matrix to find the corresponding eigenvectors? There are two eigenvectors for eigenvalue 3, and one for eigenvalue 5.
Right but you can't find the diagonalization when the two eigenvalues are the same. They are linearly dependent. Right? I just wanted to verify that I wasn't going crazy.
Once you have two identical eigenvectors for P you can't invert it to eventually find D. Or am I supposed to just assume that D is the diagonal matrix of 5,3,3 even though you can't actually get to that point.
The minimal polynomial of your matrix (x - 5)(x - 3), so it is diagonalizable.
It is diagonalizable if and only if the characteristic polynomial of your matrix, A, splits and for each eigenvalue X of A, the multiplicity of X equals n - rank (A-XI). So check to see if these criteria apply here (you have almost done the first step)
When two or more of your eigenvalues are the same, you need to search for generalized eigenvectors. These generalized eigenvectors will be linearly independent, and you can construct your P-matrix from them.
Or more simply, if and only if the minimal polynomial has the form (x - a1)(x - a2)...(x - an) where ai are the distinct eigenvalues of A. D will be the diagonal matrix having a1, a2, etc. down the diagonal and P will be the matrix whose columns are a linearly independent set of eigenvectors corresponding to the eigenvalues of A.
Can one of you help me find the generalized vectors I have no idea what to do.
Nm, I figured it out. when looking for the eigenvector for 3 it actually splits into 2. I think I did the math wrong the first time. Thanks you guys.
