What Mass Should Be Used in Joule's Experiment to Deliver 1.00 kcal?
  • Thread starter Thread starter kavamo
    Experiment
To deliver 1.00 kcal to water in Joule's experiment, a mass must descend 1.23 m over 30 descents. The calculation involves using the potential energy formula U = mg(delta)h, where g is 9.80 m/s². Converting 1 kcal to joules gives 4186 J, leading to the equation 4186 = m(9.8)(30)(1.23). The resulting mass calculated is approximately 11.57 kg. This confirms that the approach and calculations are correct for achieving the desired energy transfer.
kavamo
An experiment is conducted with a basic Joule apparatus, where a mass is allowed to descend by 1.23 m and rotate paddles within an insulated container of water. There are several different sizes of descending masses to choose among. If the investigator wishes to deliver 1.00 kcal to the water within the insulated container after 30.0 descents, what descending mass value should be used? Let g = 9.80 m/s2. (need answer is in kg)
U=mg(delta)h
1kcal=m(9.8)*30*1.23
4186 =m(361.62)
4186/361.62=m
11.576=m
Did I do this correctly?
Thanks in advance.
^ assuming your conversion of kcal to joules is correct that seems like a model solution to me.
1 Kcal = 4186 joules
As you say potential energy = mgh
Rememebr to put the units in:
E = m g h
4186 J = m kg * 9.81 m/s^2 * (30*1.23)m
Check units, J = N m = kg m/s^2 m
so m = 4186 / (9.8 * 30 * 1.23) = 11.57kg
Thanks for the reminder!
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
