What speed must the ball be thrown
  • Thread starter 1MileCrash
  • Tags
    Ball Speed
In summary, to find the initial speed required to reach a maximum height of 70m, the formula v=v0+at can be used by substituting v=0 and a=-9.8 m/s^2. This results in the equation v0=-9.8t. By solving for t using the formula x=xo+vot+(1/2)at^2 and substituting the known values of x=70 and xo=0, the value of t can be found. Then, by substituting the value of t into the equation v0=-9.8t, the initial speed required to reach a maximum height of 70m can be calculated.
1MileCrash
1,342
41
What speed must a ball be thrown vertically to reach a max height of 70m?
I originally tried to find the velocity by the fact that the velocity of the ball must be zero at a height of 70 m, accounting for 9.8 m/s^2 acceleration due to gravity (which is negative in this case)
So, if the velocity is decreased by 9.8 m/s every second, and reaches 70 m at zero, then I could find that if I knew the time that the ball is in the air.
To find the time, I could use x=xo + vot + (1/2)at^2, but then I need initial velocity!
What formula am I missing?
Try using the first equation of motion.
v=v0+at.
You know that at the maximum height the velocity is zero, using that you can find the value of v0 (in terms of g and t).
Then substitute it in second equation of motion. ;)
I'm not sure I understand how I could apply that one. I have v, as 0, but the only other value I know is a at 9.8.
0 = Vo + 9.8t
What can that tell me?
Thanks!
0 = Vo + 9.8t
Thanks!
Oops! You did a sign mistake :smile:
What you should get is this:-
0=v0-gt
For now, don't substitute g, when the equations are solved then you can substitute g.
So Vo=gt. So replace all instances of Vo with gt in the time equation, right?
Thanks!
Thanks!
Yes! :)
Do you agree with t = 2.18?
My answer comes out to be 3.74s when g=10 m/s^2.
It don't come 2.18s too when i take g=9.8 m/s^2
Since Vo is what you want to solve for, not really the time, wouldn't it make more sense to eliminate t instead?
Going that way I get vo= 21.4. Sorry I am showing no work, on a cellphone.
No, but I have no idea what you did wrong.
Alright, guess ill just have to wait until I get home, sit down, and think about it.
Here's my work for replacing Vo
Given that Xo = 0, X = 70, Vo = gt
[itex]x = x_{0} + v_{0}t + \frac{1}{2}gt^{2}[/itex]
Replace instances of Vo with gt, Xo is 0. x is 70.
[itex]70 = (gt)t + \frac{1}{2}gt^{2}[/itex]
[itex]70 = gt^{2} + \frac{1}{2}gt^{2}[/itex]
[itex]70 = 9.8t^{2} + 4.9t^{2}[/itex]
[itex]70 = 17.4t^{2}[/itex]
[itex]4.76 = t^{2}[/itex]
t = 2.18
Your last term has the wrong sign. The acceleration is -g, not g.
Of course! Ball is thrown against gravity. Accounting for that, 3.77964473..
Thanks a lot guys.
37.42 for initial velocity?
Yep you got it. :smile:
Good. Now try doing as I suggest in post #9 and solve it without the unnecessary step of calculating the time.
It wasn't unnessesary because part b asked for it anyway, but will do.
It's worth doing. And in the process you'll derive a very useful kinematic formula that will enable you to solve for the velocity in one step. (Well worth committing to memory.)
Now that you have the answer, I can say:
One thing to consider is that if the ball was instead dropped from 70m, it would reach the ground at the speed you sought [just down instead of up, that's why I said speed not velocity], and the time to reach the ground would have been part 2 of the question you mentioned.
1. What does the speed of the ball depend on?
The speed of the ball depends on several factors, including the initial force applied to the ball, the angle at which it is thrown, and the air resistance it encounters during flight.
2. How is the speed of the ball measured?
The speed of the ball can be measured using a radar gun or a speedometer. It can also be calculated using the distance traveled and the time it takes to travel that distance.
3. What is the relationship between speed and distance?
The speed of the ball is directly related to the distance it travels. The greater the speed, the farther the ball will travel in a given amount of time.
4. Can the speed of the ball be increased mid-flight?
No, the speed of the ball cannot be increased once it has been thrown. However, it can be affected by external forces such as wind or gravity.
5. What is the optimal speed for throwing a ball?
The optimal speed for throwing a ball depends on the desired trajectory and distance. A higher speed may be needed for longer distances or to overcome air resistance, while a lower speed may be more accurate for shorter distances.
