What time interval between wave fronts in S and S'?
The discussion focuses on calculating the time interval between wave fronts arriving at observer C' from a moving train, which is 1.0 km long and traveling at 150 km/h. The solution involves using the formula Δt = t(back) - t(front), incorporating the train's speed and the speed of light. Participants clarify that while the train's speed is a small fraction of light speed, special relativity (SR) is not necessary for this scenario. They emphasize understanding the derivation of the formula and the impact of length contraction on the distances involved. The conversation concludes with a reminder that the formula accounts for the distance the train moves while the waves propagate.
Breadsticks
1-9: Assume the train is 1.0km long as measured by the observer at C' and is moving at 150km/h. What time interval between the arrival of the wave fronts at C' is measured by the observer at C in S?
[/B]
The solution from the manual is Δt=t(back)-t(front)= 500/(c-(150/3.6m/s))-500/(c+(150/3.6m/s))=4.6*10^-13
How can it use the distance it travels in S'? It doesn't travel that distance in S.
The speed of the train is a tiny fraction of the speed of light. No need for SR here.
Thanks for the reply. If the train was moving at a non-negligible fraction of the speed of light, I would then simply find where the waves meet to figure distance for each then use the above procedure with the modified distances?
I would use the exact procedure with the only difference being the modified distances (the length of the train in frame S).
Be sure you understand how that formula is derived.
Right, there would be length contraction but what about the distance the train has moved while the wave is moving?
That is covered by the formula you quoted. (Understand how it is derived!)
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
