What value of the velocity should I insert in the equation?
  • Thread starter Thread starter antigona
    Value Velocity
The discussion revolves around calculating the displacement of a projectile considering air drag, using a specific formula. The user is uncertain about which velocity value—initial velocity or the X component—should be used in the equation. A response highlights that the equation of motion used may be incorrect, suggesting the inclusion of mass and correcting the gravitational term. It emphasizes the need to focus on the y-component of the initial velocity for accurate calculations. The conversation underscores the importance of correctly applying physics principles to ensure precise projectile motion analysis.
antigona
Hi,
My problem is very simple... but yet it rises some doubt. I am calculating how long a projectile goes taking into account air drag. For the displacement I have the following formula:
x=(v0+Vterminal)/k*(1-e^(-kt)-Vterminal*t+x0
where k is the air drag coefficient
I know that this formula already includes both components of the velocity, thus it should give the correct displacement.
The equation states that my initial velocity is: 31.1m/s
The X component of the velocity is: 15.55m/s.
Which value of the velocity should i insert on the equation?
I have done the calculations with both and the results differed by very little, hence my confusion.
Appreciate the help, thanks.
R.
Which equation of motion did you solve to get that formula for the displacement?
dv/dt=-kv+g
You're missing an m in there I think and +g should be -g. Since you have a g in that particular equation of motion the v and x you calculate will be in the y-direction. Therefore you need to calculate the y-component of the initial velocity.
