What wrong with Lorent transformation here?
  • Thread starter Thread starter AlienUFO
    Transformation
AlienUFO
Say we build a train that can travels revolve Earth continuously. And inside the train there is another smaller train that also revolves Earth but travels in opposite direction with the bigger train.
The problems is: relative to observer on earth, the bigger train is under L.transformation but not the smaller one. Hence the time in bigger train seems slower but not the smaller train. But for the observer on the bigger train, the smaller train is undergo another L.transformation, hence the smaller train's time should be slower.
The speed of the smaller train should cancel the L.transformation relative to earth, hence where the time clock of the train should I refer to?
Is there something wrong?
Let me get this straight. We have two trains, a larger train traveling with a constant velocity (relative to the Earth's surface) anti-clockwise around the Earth (for the sake of argument); and a smaller train, inside the larger train, traveling at the same velocity (relative to the larger train) but in the opposite direction to the larger train. Is this correct?
Yup. Thank you Hootenanny, my english is just...
I don't see a problem. Without the "inner train", an observor on Earth would see time running more slowly on the train while an observor on the train would see time running more slowly on the earth. Adding the "inner train" doesn't present anything new- it's just part of the Earth fram of reference.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
