Understanding velocity and acceleration
In summary, the equation v = s/t represents average speed over a period of time, while the equation accel = dv/dt represents instantaneous speed at a specific time. These two cannot be represented by the same variable, 'v'. Additionally, the differentiation in post #1 is only valid if s is constant and t is variable.
coverband
171
speed = distance/time
v=s/t
Acceleration = dv/dt = -s/t^2 ?
In the equation v = s/t, 'v' represents average speed over the period from time 0 to time t.
In the equation accel = dv/dt, 'v' represents instantaneous speed at time t.
Unless acceleration is always zero, average speed and instantaneous speed are different items, and cannot be represented by the same variable letter ('v' in this case).
Likes coverband
Another thing to add is that the differentiation in post #1 would be valid only if ##s## were a constant and ##t## were a variable. Does that make sense?
No because when deriving an equation for v we start with a = dv/dt -> dv = a dt -> v=[int]a dt -> v = u + at. This is how Wikipedia derives the first equation of motion. They treat a as a constant. Thanks for your first answer though
I said constant ##s##, not constant ##a##. My comments refer specifically to $$
\frac{d}{dt} \left( \frac{s}{t} \right) = -\frac{s}{t^2},
$$which is valid only if ##s## is constant.
1. What is the difference between velocity and acceleration?
Velocity is a vector quantity that describes the rate of change of an object's position over time, including its direction. Acceleration, on the other hand, is a vector quantity that describes the rate of change of an object's velocity over time.
2. How are velocity and acceleration related?
Acceleration is the derivative of velocity, meaning it is the rate of change of velocity over time. In other words, if an object's velocity changes, it will experience acceleration.
3. What is the unit of measurement for velocity and acceleration?
Velocity is typically measured in meters per second (m/s) or kilometers per hour (km/h), while acceleration is measured in meters per second squared (m/s²) or kilometers per hour squared (km/h²).
4. How do you calculate velocity and acceleration?
Velocity can be calculated by dividing the change in an object's position by the change in time. Acceleration can be calculated by dividing the change in an object's velocity by the change in time.
5. Can an object have a constant velocity and still experience acceleration?
Yes, an object can have a constant velocity and still experience acceleration if its direction changes. This is because acceleration takes into account the change in both speed and direction.
  • Mechanics
  • Mechanics
