When can the velocity gradient be set to zero?
The discussion revolves around the conditions under which the velocity gradient can be set to zero in a two-dimensional flow field, specifically focusing on the u-velocity component described by a given equation. The context includes considerations of incompressibility and the implications of velocity gradients and divergence in fluid dynamics.
  • Participants explore the relationship between velocity gradients and divergence, questioning the assumptions made about the velocity gradient being zero. There are attempts to clarify the definitions and differences between these concepts.
Participants are actively engaging in clarifying the definitions of velocity gradient and divergence, with some questioning the initial assumptions about incompressibility and its effects on the flow. There is no explicit consensus, but the discussion is productive in exploring these concepts.
Some participants note the need for the problem statement to specify that the fluid is incompressible, which may influence the assumptions about the velocity gradient. There is ongoing discussion about the implications of compressibility on fluid behavior.
ScareCrow271828
An experimentalist has measured the u-velocity component of a two-dimensional flow
field. It is approximated by
u = (1/3)( xy) (y^2)
It is also known that the v-velocity is zero along the line y=0.
∇V=du/dx+dv/dy (partial derivatives)
The solution is found by setting du/dx+dv/dy=0 (partial derivatives), solving the differential equation and then using the boundary conditions at v=0, y=0 to find the constant.
How can we set the velocity gradient equal to zero? Why is it safe to assume that there is no velocity gradient?
The problem statement should state that the fluid is incompressible.
The velocity gradient is not zero. Do you know the difference between the velocity gradient and the divergence of the velocity? If so, please elaborate.
Thank you, so if the fluid is incompressible the layers do not have a velocity towards each other? If it was compressible the fluid layers would be able to compress towards each other?
As I understand the velocity gradient is the velocity that the layers of a fluid move in respect to each other. The divergence of the velocity is kind of the total rate of change of the field, since it is a sum of the components partial derivatives.
If the divergence is nonzero there is a net flow in or out of the point. I.e. it is a sink or a source.
A non-zero divergence also applies to a distributed source or accumulation.
You have been confusing the gradient of the velocity vector with the divergence of the velocity vector. The divergence of the velocity is not the same as the gradient of the velocity. The gradient is the del operator applied to the velocity vector. The divergence is the del operator dotted with the velocity vector. In post #1, the right hand side of your equation is the divergence of the velocity vector, not the velocity gradient.
