When elctrons pass through a bulb it poduces heat and light why?
  • Thread starter Thread starter khizman
    Bulb Heat Light
Electrons passing through a light bulb filament generate heat and light due to collisions with filament atoms, which causes the atoms to vibrate and heat up. Thinner conductors heat more easily than thicker ones due to higher resistance to electron movement. The vibrating atoms can temporarily boost their bound electrons to higher energy levels, releasing energy as photons when returning to normal levels. While metal atoms primarily emit infrared light, high temperatures can produce visible light. This process illustrates the transformation of electrical energy into thermal and light energy.
khizman
:confused: ??
Science news on Phys.org
This may help you.
http://science.howstuffworks.com/light-bulb2.htm
As the electrons zip along through the filament, they are constantly bumping into the atoms that make up the filament. The energy of each impact vibrates an atom -- in other words, the current heats the atoms up. A thinner conductor heats up more easily than a thicker conductor because it is more resistant to the movement of electrons.
Bound electrons in the vibrating atoms may be boosted temporarily to a higher energy level. When they fall back to their normal levels, the electrons release the extra energy in the form of photons. Metal atoms release mostly infrared light photons, which are invisible to the human eye. But if they are heated to a high enough level -- around 4,000 degrees Fahrenheit (2,200 degrees C) in the case of a light bulb -- they will emit a good deal of visible light.
Basically its energy being transformed.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
