When reactions occur, how can you differentiate between A2B2 and 2AB?
In the discussion, the focus is on determining the correct products of a double replacement reaction involving sodium sulfate (Na2SO4) and calcium chloride (CaCl2). The key point is that the reaction produces calcium sulfate (CaSO4) and 2 sodium chloride (NaCl), rather than sodium dichloride (Na2Cl2). This conclusion is based on the charges of the ions involved: sodium ions have a +1 charge and chloride ions have a -1 charge, meaning one sodium ion pairs with one chloride ion. The discussion emphasizes that in chemical reactions, the simplest molecular ratios are preferred, leading to the formation of 2NaCl instead of Na2Cl2.
wasteofo2
Take this double replacement reaction for example:
Na_2SO_4 + CaCl_2
How am I supposed to tell whether the product will be CaSO_4 + Na_2Cl_2 or CaSO_4 + 2NaCl?
Obviously, there's a difference between Calcium Sulfate + 2 Sodium Chloride molecules and Calcium Sulfate + Sodium DiChloride, but how can I figure out which it will be?
Thanks for any help,
Jacob
Chemistry news on Phys.org
A2B2 (almost) never exists. Whenever the numbers of different atoms in a molecule have a common divisor, you divide by that number to reduce it to the simplest ratio. Why ? Because in most cases, it can be shown that the simplified structure (AB rather than A2B2) is the energy minimizing structure.
So it's extremely rare to find (inorganic) molecules like A2B2, A2B4, A3B6, A2B2C4, etc. Hydrogen peroxide is a notable exception, but then again, peroxide linkages are usually quite unstable.
So, in your specific problem, the product formed is 2NaCl (not Na2Cl2).
The products will be CaSO_4 + 2NaCl Why would you get Na_2Cl_2? Sodium ions have a charge of +1 and Chloride ions have a charge of -1. It only takes 1 sodium ion to go with 1 chloride ion.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
I'm trying to find a cheap DIY method to etch holes of various shapes through 0.3mm Aluminium sheet using 5-10% Sodium Hydroxide. The idea is to apply a resist to the Aluminium then selectively ablate it off using a diode laser cutter and then dissolve away the Aluminium using Sodium Hydroxide. By cheap I mean resists costing say £20 in small quantities. The Internet has suggested various resists to try including... Enamel paint (only survived seconds in the NaOH!) Acrylic paint (only...
