When Should Gravity's Potential Energy Be Negative in Energy Calculations?
In energy calculations, gravitational potential energy can be negative when the reference point for zero potential energy is set above the object's position. For a ball compressed in a barrel, if the muzzle is defined as the zero potential energy point, then the potential energy is negative when the ball is below this point. The elastic potential energy of a spring is always positive, calculated as +0.5kx², regardless of the spring's position. The correct energy conservation equation combines both gravitational and spring potential energies to find the velocity of the ball when it exits the barrel. After correcting the setup and calculations, the final velocity was determined to be approximately 4.784 m/s.
rsala
my question is, when using energy conservation when do i put the potential energy of gravity negative? if its under where it set my potential energy to 0? or am i wrong, is gravity's potential energy always positive (except at my set u=0 point) ?
can someone explain this to me, having trouble getting ANYthing done because i do not understand how to set up these homework questionsfor example, this is a ball pushed into a barrel, compressing the spring, ball has initial velocity 0
here are the values,
k = 667 N/m
mass of ball = 1.5kg
ball is pushed into tube .25 meters
if u=0 is set at the mouth of the barrel, then the initial potential energy is mgh+.5kx^2?
or is it -mgh+.5kx^2? -mgh-.5kx^2?
You get to define where the potential energy is 0. Everything above that is positive, below that negative.
what about the springs energy is that negative as well?
meaning if i set the muzzle of the gun to be potential energy 0,, is the total potential energy at the compressed initial part
-mgh-.5kx^2?
Yup, because you also defined the springs 0 potential energy mark at y=0
im trying to find the velocity once it is at y=0 (once it leaves the gun)
i am setting
-mgh - \frac{1}{2}kx^{2} = \frac{1}{2}mv^{2}
i solve this for v and i receive
<br /> \sqrt{\frac{2(-mgh-\frac{1}{2}kx^{2})}{m}}<br />
i do not receive the correct answer, i get 5.72
k = 667 N/m
i am placing -.25 into the formula since it is below the muzzle, anyone see where i went wrong?
U = mgh+.5kx^2
You get the negatives from the the springs compression and the height, you didn't use
-mgh-.5kx^2 THEN also set x=-.25 did you?
yes i did, i just tried again with correct negatives i think (i see where i went wrong last time)
and i got answer: 3.38m/s, wrong still though
mgh + \frac{1}{2}kx^{2} = \frac{1}{2}mv^{2}
That would be the problem:
\sqrt{\frac{2(mgh+\frac{1}{2}kx^{2})}{m}}
Where x=-.25
The potential energy of the ball is +mgh. If the ball is below th etop of the barrel, h is negative, so mgh will then be negative. The elastic energy of the spring is always equal to +kx^2/2 if its unstretched position is at the top of the barrel.
jesus wrong again, i got 22.89166 m/s this time, lol
i have used
\sqrt{\frac{2((1.5)(9.8)(-.25)+\frac{1}{2}(667)(-.25^{2}))}{1.5}}
o nvm i forgot the sqrt, i got correct answer now! 4.784
thank you feldoh, kamerling
4.784 m/s once it leaves muzzle
solved now though, i didnt know how to properly set any of the initial and final energies, so i couldn't solve it initially, i got it now though.
thanks again
i have used
Ah, that's good. I was beginning to think I just made up everything I told you since it's been a while since I've done that lol XD
