Where Does Current Go With a 4V Servo?
  • Thread starter Thread starter pug
    Current
A 4V power source providing only 50 mA cannot meet the 200 mA requirement of a 4V servo, leading to potential underperformance. The current from the power supply will flow into the servo, but it may not be sufficient for proper operation, possibly causing overheating. A capacitor can help if the servo is active less than 25% of the time, storing energy for brief bursts of activity. However, if the servo is continuously active, the capacitor won't provide adequate support. Proper voltage and current ratings are crucial for circuit functionality, and exceeding capacitor voltage ratings can lead to failure.
pug
Hi I am trying to do a DIY with a servo and I was wondering...
If I have a power source (e.g. 4V with 50 mAmps) connected to a 4V servo with a running current requirement of 200 mAmps...where will the current from the power source go? Will it just heat the motor of the servo? Or if there was a capacitor will the capacitor collect the current and then periodically discharge it to the motor?
I have been taught that voltage is akin to the 'height' of the electron and current is the amount of electrons that are flowing. So if the voltage is correct will the electrons compile in the capacitor like a dam until it 'bursts' or discharge?
thank you for any help!
If your servo requires 200 mA, and you picked a power supply that can only deliver 50 mA, then you could be under-serving your servo. What little current your power supply is providing will still go into the servo. Have you tried it yet? Please report on what happens.
If your servo is always doing something, a capacitor will not help. If your servo is only active, say less than 25% of the time, yes a right-sized capacitance will help (depends on how long the servo is continuously active).
Why use with an undersized power supply to begin with?
The circuit should not over-voltage the capacitor, capacitors have max voltage ratings. A capacitor voltage will rise at it charges, and it will accumulate less and less charge as the voltage at the terminal connected to the charging voltage source rises. The capacitor should not burst or overcharge, it will just get full and then current will stop flowing because the voltage at the input terminal of the capacitor will equal the voltage at the output of the power supply.
The below is more elaborate / formal / better explanation.
http://www.electronics-tutorials.ws/rc/rc_1.html
In general, current just goes around and around the circuit. Using the water analogy, it's like a circular piping loop.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
