Where Does the Crate Strike the Wall?
  • Thread starter Thread starter Brand3n
    Friction Truck
The discussion focuses on a physics problem involving a crate on a truck bed during braking. The coefficients of friction are provided, and the truck stops from an initial speed of 15 m/s. The calculations reveal that the crate's acceleration relative to the truck is 1.962 m/s², and it moves 2.835 m during the truck's stopping time. After the truck stops, the crate continues to slide forward due to its inertia, leading to a need for further calculations to determine the final distance it travels before hitting the wall. The conversation emphasizes the importance of correctly applying the coefficients of friction and understanding the relative motion between the crate and the truck.
Brand3n
The coefficients of friction between the flat bed of the truck and crate are (coefficient of static friction) = 0.8 and (coefficient of kinetic friction) = 0.7. The coefficient of kinetic friction between the truck tires and the road surface is 0.9. If the truck stops from an inital speed of 15 m/s with maximum braking (wheels skidding), determine where on the bed the crate finall comes to rest or the velocity relative to the truck with which the crate strikes the wall at the forward edge of the bed.
The distance from the crate to the wall at the forward edge of the bed is 3.2m
Truck is going to the right.
Friction Force = Coefficient of Friction * Normal Force.
X=Xinitial+v*t
V=Vinitial+a*t
X=Xinitial+Vinitial*t+(1/2)*a*t^2
V^2=Vinitial^2+2*a*(X-Xinitial)
M*Atruck=(.9)MG
Atruck=(.9)(9.81)=8.829 m/s^2 going to the left
V=Vinitial+A*T
15=0+(8.829)(T)
T=1.69895 , time it takes for the truck to stop
(coeff. of kinetic friction of the crate)*Normal Force=M*Acrate
(.7)M(9.81)=M*(Acrate)
Acrate=6.867
acceleration of the crate in relation to the truck = 6.827-8.829 = 1.962 m/s^s going to the right
V^2 = Vinitial + 2(A)(X-Xinitial)
V^2 = 0 + 2(1.962)(3.2)
V = 3.54356 m/s
What did I do wrong? I couldn't figure out how to use the coeff. of static friction of the crate and truck bed.
Woops! Wrong section I guess haha. This stuff is advanced for me -_-
It seems to me that "Acrate=6.867" is the acceleration relative to the truck. Just what you want. Don't subtract the truck's acceleration.
I feel like that's the acceleration of the crate relative to the ground. An answer I found on another site was around 2.46 m/s or something and that would make my number higher rather than lower.
Not 100% sure though, does anyone else have any ideas?
Sorry, I am mistaken. I see that if there is zero friction then Acrate = 0 and that is certainly not relative to the truck. So your a = 1.962 is correct.
But your final velocity calc doesn't make sense.
In the 1.7 s it takes the truck to stop, the crate will move d = ½at² = ½(1.962)*1.7² = 2.835 m. When the truck is stopped, the crate is still moving and has another 0.35 m to go before it hits. Slowing down due to friction now. You have another calc to do.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
