Where Is the Center of Mass in a Club Axe?
The discussion focuses on calculating the center of mass of a club axe consisting of a 9 kg stone and a 2.5 kg stick, with the stick measuring 80 cm and the stone 18 cm. To find the center of mass, the formula used is \(\sum mx / (m1 + m2)\), where \(m1\) and \(m2\) represent the masses of the stone and stick, respectively. The user expresses confusion about the calculations and seeks guidance on how to approach the problem effectively. Understanding the geometric center of both components is essential for solving the problem.
  • Understanding of center of mass calculations
  • Familiarity with basic physics concepts
  • Knowledge of mass and distance measurements
  • Ability to apply mathematical formulas
  • Study the concept of center of mass in physics
  • Practice using the center of mass formula with different mass distributions
  • Learn about the geometric center and its application in physical objects
  • Explore problems involving composite objects in physics
Students studying physics, particularly those focusing on mechanics and center of mass calculations, as well as educators seeking to explain these concepts effectively.
gl7
1. a club ax that consists of a symmetrical 9 kg stone is attached to the end of a uniform 2.5 kg stick. stick is 80 cm long, stone is 18 cm.
how far is the center of mass from the handle end of the club-ax?
3. i for the life of me not know how to go about solving, i am not looking for handouts i really want to learn how to do, if could please explain to me. please and thanks a lot
Do you know how to find the center of mass of two points? If so, you can find the geometrical center of the stone and handle and be one step from the solution.
i think so, i am using \sum mx / m1 + m2.
i am just completely lost on this topic, everything i try is wrong. thanks for the help but i think i will need to figure in my next class
  • · Replies 25 ·
