Where would I find out more about wind force?
  • Thread starter Thread starter Kyle Stanley
    Force Wind
The discussion focuses on finding a simplified formula for wind force acting on a surface, particularly in relation to kite design for varying wind conditions. The user is interested in understanding how to calculate the force exerted by wind, referencing a formula involving kinetic energy, area, and air density. They highlight the importance of drag coefficients and aerodynamics in this context but seek a more straightforward approach for practical applications. The conversation emphasizes the need for appropriate kite size to manage forces in high winds versus light breezes. Overall, the thread aims to guide users in modeling wind force effects simply and effectively.
Kyle Stanley
This curiosity began with my attempt to find a general simplified formula for wind force displaced perpendicular to a surface with relation to the velocity of wind and the area of the surface {analogous to the simple models in UP 1 for describing motion}.
This curiosity had its orgins with a kite project that I wish to modify to handle high winds and an ultra-light model for light breeze. I know such an approach must exist, I saw an equation several years ago when I was curious how to determine the maximum force from an F5 tornado.
So I have found some things involving drag coefficients and with this in mind... I am sure that this goes heavy into things like aerodynamics which is ostensibly way over my head and also into things pertainent to structural analysis. But I am looking for the simplified version so I can make sure to both provide adequete lift and adequate strength to the kite and line.
This is probably used to design sails for sailboats, wind turbines, et al.
So essentially my question is where am I introduced to this type of study and if possible how can one model this in a simple manner without the need for drag coef.?
Thanks for any suggestions.
Kyle
I found something on this
E=Avt(rho)v^2
where E is the total kinetic energy
A the area perpendicular to the displacement of the velocity
t time
(rho) is the air density
this is what I was after, a formula to discuss the actual force {energy in this case}
Charlatanza said:
With high winds you should try to have a big kite, as the force of the winds will mean that the area displaced by the wind is big enough. A small kite will have too much force on it and thereforebe swirling out of control!
With a small breeze you should try to use a small kite, as it is light to be taken up.
Thanks for your response.
Kyle
I have Mass A being pulled vertically. I have Mass B on an incline that is pulling Mass A. There is a 2:1 pulley between them. The math I'm using is: FA = MA / 2 = ? t-force MB * SIN(of the incline degree) = ? If MB is greater then FA, it pulls FA up as MB moves down the incline. BUT... If I reverse the 2:1 pulley. Then the math changes to... FA = MA * 2 = ? t-force MB * SIN(of the incline degree) = ? If FA is greater then MB, it pulls MB up the incline as FA moves down. It's confusing...
Hi. I noticed that all electronic devices in my household that also tell time eventually lag behind, except the ones that get synchronized by radio signal or internet. Most of them are battery-powered, except my alarm clock (which runs slow as well). Why does none of them run too fast? Deliberate design (why)? Wrong temperature for quartz crystal? Decreasing battery voltage? Or just a coincidence?
