Whether the boy can catch the ship? relative velocity
The discussion centers on a physics problem involving relative velocity, where a boy attempts to catch a moving boat. Participants suggest using vector analysis and right triangle geometry to approach the problem, considering the boy's swimming and running paths as vectors. Key points include the importance of the boy's direction and the angles involved, which affect his velocity and time to reach the boat. The use of the law of sines is proposed to relate the boy's and boat's displacements, leading to a formula for the boy's effective velocity based on various angles. The conversation emphasizes the need for calculus to optimize the boy's path for minimal time to catch the boat.
jessicaw
see upload file
consider relative velocity and show that boy can go back to origin.
thanks!
type the problem statement... your posted file's font is too small to read
very urgent i have upload a clear file now thanks for answering
Hmmm, since it doesn't say anything about the boy's direction when he starts swimming I assume they want you to consider a right triangle...of course this depends on your level of physics class also... if you find this is not the case then use the law of cosines to solve the problem .
Consider a right triangle with edge AB as the bank shore. edge AC as the path of the boat and edge BC as the path the boy swims to reach the boat
angle ABC = 90 deg
and angle BAC = 15 deg
now the problem becomes easy if you think of these edges as vectors So edge AC is the vector representing the boat's velocity. The edges CB and AB represent components of the boys velocity
then find the magnitude of the boy's velocity by sqrt ( CB^2 + AB^2 ) and violla ... v(max) = sqrt(20)
again... this is assuming the boys swims perpendicular to the shore.. if you're in a college course with a calculus prerequisite ... you might want to introduce some variable angle theta for angle ABC and do some calculus to find out which angle would give you a minimum time. (related rates) and then solve for the vector sum that way
angle ABC = 90 deg
the boys direction is actually arbitary.
Direction should affect your time traveled by the boy, and thus your velocity of the boat.
Maybe you found a way the angles cancel out to an identity? I'm not sure I'm just considering the problem in my head.
angle ABC = 90 deg
CB and AB do not represent the components of the boy's velocity. boy can run different
time on the ground and swim for different time. also you can't do velocity addition stuff here since all three velocities are relative to the ground only.
i think i got some way out of this.
lets assume that boy is able to meet the boat. i am assuming that the boy's running path
on the river bank is downwards if the boat is also going downwards. let boy run on the river bank for time t1 and swim in the river for time t2. since boy meets
the boat, we can add the displacement vectors
\bar{u}t=\bar{\mathrm{v}_1}t_1+\bar{\mathrm{v}_2}t_2 where t =t1+t2
is the total time of journey. during this time the boat also reaches that point of
meeting. let the boat make angle \theta with the river bank. and let
\alpha be the angle between \bar{v_1} and \bar{v_2}.
so \alpha is an external angle of the triangle formed by three displacement vectors.
we will now use law of sines here. the angle in front of the side with length equal to
ut is \pi-\alpha. angle in front of the side with length equal to
v_2 t_2 is \theta and the angle in front of the side with length equal
to v_1 t_1 is (from geometry) \alpha-\theta. so law of sines gives
\frac{v_2 t_2}{\sin \theta}=\frac{ut}{\sin \alpha}=\frac{v_1 t_1}{\sin(\alpha-\theta)}
from here we get (since t=t1+t2)
u=\frac{t_2}{(t_1+t_2)} \sin\alpha \, \frac{v_1t_1}{\sin(\alpha-\theta)} ...1)
and
t_2 =\frac{v_1}{v_2}\, \frac{\sin \theta}{\sin(\alpha-\theta)}\, t_1...2)
we can use eq 2 to eliminate t1 and t2 from eq 1. and we can simplify eq. 1 as
u=\frac{v_1 v_2 \sin \alpha}{v_2 \sin(\alpha-\theta)+v_1 \sin \theta}
since \theta is constant, and v1 and v2 are also constants, u is function of \alpha. we can now use methods of calculus to maximize u. when we equate the first derivative of u with respect to \alpha
to zero and evaluate the expression we get the condition,
\cos \alpha=\frac{v_2}{v_1}
so the maximum value of u becomes
u_{max}=\frac{v_1 v_2 \left[1-\frac{v_2^2}{v_1^2}\right]^{1/2} }{v_2 \left[1-\frac{v_2^2}{v_1^2}\right]^{1/2} \cos \theta - \frac{v_2^2}{v_1} \sin \theta + v_1 \sin \theta }
i hope my calculations and reasoning is correct. please check it for different special cases.
