Which ∆H Should Be Used in Chemical Equations and Potential Energy Diagrams?
When calculating the enthalpy change (∆H) for a chemical reaction, it is important to use the ∆H per mole of the substance involved. This approach ensures consistency in your equations and aligns with standard practices in thermodynamics. To confirm the correct unit usage, writing out a proper unit formula can help clarify whether to use moles or grams, as it will show what cancels out in your calculations. Using ∆H per mole is the recommended method for both the chemical equation and the potential energy diagram.
rowkem
So,
I did 5 labs where I burned certain things and found the temp. diff. in the calorimeter. That said, I calculated the ∆H for the entire system, the ∆H per gram of system substance, and the ∆H per mol of system substance.
Im wondering which ∆H I should be putting into my chemical equation for the reaction, as well the ∆H I should be putting into my potential energy diagram? I have a feeling its the ∆H per mole but, I'd like a second opinion. Thanks,
Chemistry news on Phys.org
Anyone?
You should do it on a per mole basis.
Most likely you want to use the mols of the substance in your equations. Write out a proper unit formula and you can see for sure whether you need the mols or grams based on what cancels and what you end up with.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
